Fundamentals of scaling and psychophysics . Wiley series in behavior, 1978. ,
Highlights and surface gloss perception, Journal of Vision, vol.2, p.3, 2002. ,
Computer-generated watercolor, p.97, 1997. ,
Stylization and abstraction of photographs, ACM TOG (Proc. of SIGGRAPH 2002, pp.769-776, 2002. ,
Recognition of surface reflectance properties from a single image under unknown realworld illumination, Proc. of the IEEE Workshop on Identifying Objects Across Variations in Lighting, 2001. ,
A psychophysically-based model of surface gloss perception, Proc. of SPIE Human Vision and Electronic Imaging, 2001. ,
How do humans determine reflectance properties under unknown illumination? IEEE Workshop on Identifying Objects Across Variations in Lighting, 2001. ,
Real-world illumination and the perception of surface reflectance properties, Journal of Vision, vol.3, issue.5, pp.347-368, 2003. ,
A nonphotorealistic lighting model for automatic technical illustration, SIG- GRAPH '98, pp.447-452, 1998. ,
Human facial illustrations: Creation and psychophysical evaluation, ACM TOG, vol.23, issue.1, 2004. ,
Image and video based painterly animation, NPAR '04, pp.113-120, 2004. ,
Crowdsourcing graphical perception: using mechanical turk to assess visualization design, ACM CHI '10: Proc. of the 28th int. conf. on Human factors in computing systems, 2010. ,
Coherent line drawing, NPAR '07, pp.43-50, 2007. ,
Is accurate occlusion of glossy reflections necessary? In APGV '07, pp.91-98, 2007. ,
Effects of global illumination approximations on material appearance, ACM TOG (Proc. of SIGGRAPH 2010, 2010. ,
Painterly rendering for animation Use of image-based information in judgments of surface-reflectance properties, Journal of the Optical Society of America A: Optics, Image Science and Vision, vol.15, p.12, 1996. ,
Let's Draw Manga: Using Color, 2005. ,
Toward a psychophysically-based light reflection model for image synthesis, pp.0-55, 2000. ,
Physically Based Rendering: From Theory to Implementation Visual equivalence: towards a new standard for image fidelity, ACM TOG (Proc. of SIGGRAPH, 2004. ,
Automatic Pen-and-Ink Illustration of Tone, Gloss, And Texture, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00454208
Shape-dependent gloss correction, APGV '08, pp.123-130, 2008. ,
The influence of shape on the perception of material reflectance Evaluation of real-world and computergenerated stylized facial expressions, Measuring and modeling anisotropic reflection. SIG- GRAPH '92 26, pp.16-265, 1992. ,
Toward a perceptual space for gloss, p.4, 2009. ,
Rendering parametric surfaces in pen and ink, SIGGRAPH '96, pp.469-476, 1996. ,
Real-time video abstraction, ACM TOG (Proc. of SIGGRAPH, 2006. ,
Using npr to evaluate perceptual shape cues in dynamic environments, NPAR '07, pp.85-92, 2007. ,
Printed patterns for enhanced shape perception of papercraft models, Computer Graphics Forum, vol.29, issue.2, pp.625-634, 2010. ,
From image parsing to painterly rendering, ACM TOG, vol.29, issue.1, 2009. ,
