Single sample modal identification of a nonstationary stochastic process, IEEE Transactions on Automatic Control AC, vol.30, issue.1, pp.66-74, 1985. ,
, Subspace Identification for Linear Systems: Theory, Implementation, Applications, 1996.
Reference-based stochastic subspace identification for output-only modal analysis, Mechanical Systems and Signal Processing, vol.13, issue.6, pp.855-878, 1999. ,
Nonstationary consistency of subspace methods, IEEE Transactions on Automatic Control AC, vol.52, issue.6, pp.974-984, 2007. ,
Modal parameter estimation from inconsistent data sets, Proc. 18th International Modal Analysis Conference, pp.763-771, 2000. ,
Consolidation of modal parameters from several extraction sets, 2000. ,
Identification of modal parameters from inconsistent data, Proc. 20th International Modal Analysis Conference, pp.809-815, 2002. ,
Merging strategies for multi-setup operational modal analysis: application to the Luiz I steel arch bridge, Proc. 27th International Modal Analysis Conference, 2009. ,
Ambient vibration re-testing and operational modal analysis of the Humber Bridge, Engineering Structures, vol.32, issue.8, pp.2003-2018, 2010. ,
Ambient and free vibration tests of the Millau Viaduct: Evaluation of alternative processing strategies, Engineering Structures, vol.45, pp.372-384, 2012. ,
Blind subspace-based eigenstructure identification under nonstationary excitation using moving sensors, IEEE Transactions on Signal Processing SP, vol.50, issue.1, pp.41-48, 2002. ,
URL : https://hal.archives-ouvertes.fr/inria-00072616
Merging sensor data from multiple measurement setups for nonstationary subspace-based modal analysis, Journal of Sound and Vibration, vol.249, issue.4, pp.719-741, 2002. ,
Modular subspace-based system identification from multi-setup measurements, IEEE Transactions on Automatic Control. In press ,
Crystal clear data fusion in subspace system identification and damage detection, Proc. 5th International Conference on Bridge Maintenance, Safety and Management, 2010. ,
Pre-and post-identification merging for multi-setup OMA with covariance-driven SSI, Proc. 28th International Modal Analysis Conference, 2010. ,
Data merging for multi-setup operational modal analysis with data-driven SSI, Proc. 28th International Modal Analysis Conference, 2010. ,
, Data fusion for system identification of the Humber Bridge, 2011.
Using local tests to estimate convergence rates for identification, Proceedings of the 39th IEEE Conference on Decision and Control, pp.1985-1990, 2000. ,
, Convergence rates for eigenstructure identification using subspace methods, pp.1550-1554, 2000.
The asymptotic variance of subspace estimates, Journal of Econometrics, vol.118, issue.1-2, pp.257-291, 2004. ,
Towards a state-space polytopic uncertainty description using subspace model identification techniques, International Journal of Control, vol.76, issue.15, pp.1570-1583, 2003. ,
Uncertainty calculation in (operational) modal analysis, Mechanical Systems and Signal Processing, vol.21, issue.6, pp.2359-2373, 2007. ,
Uncertainty bounds on modal parameters obtained from stochastic subspace identification, Mechanical Systems and Signal Processing, vol.22, issue.4, pp.948-969, 2008. ,
In-flight monitoring of aeronautic structures: vibration-based on-line automated identification versus detection, IEEE Control Systems Magazine, vol.27, issue.5, pp.27-42, 2007. ,
Vibration based structural health monitoring of an arch bridge: From automated OMA to damage detection, Mechanical Systems and Signal Processing, vol.28, pp.212-228, 2012. ,
Maximum likelihood identification of non-stationary operational data, Journal of Sound and Vibration, vol.268, issue.5, pp.971-991, 2003. ,
Ambient vibration studies for system identification of tall buildings, Earthquake Engineering & Structural Dynamics, vol.32, issue.1, pp.71-95, 2003. ,
Noncontact operational modal analysis of structural members by laser doppler vibrometer, Computer-Aided Civil and Infrastructure Engineering, vol.24, issue.4, pp.249-265, 2009. ,
Data fusion for frequency domain stochastic subspace identification, Proceedings of the 5th European Conference on Structural Control (EACS), 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00715888
Description of Z24 benchmark, Mechanical Systems and Signal Processing, vol.17, issue.1, pp.127-131, 2003. ,
Efficient identification of input dynamics for correlation function-based subspace identification, Proc. 18th IFAC World Congress, pp.6511-6516, 2011. ,
Stochastic system identification for operational modal analysis: a review, Journal of Dynamic Systems, Measurement, and Control, vol.123, issue.4, pp.659-667, 2001. ,
Comparative study of modal analysis techniques for bridge dynamic characteristics, Mechanical Systems and Signal Processing, vol.17, issue.5, pp.965-988, 2003. ,
On the achievable accuracy of structural system parameter estimates, Journal of Sound and Vibration, vol.34, issue.1, pp.63-79, 1974. ,
Robust subspace based fault detection, Proc. 18th IFAC World Congress, 2011. ,
Uncertainty quantification in operational modal analysis: Application to a damaged pre-stressed concrete bridge, Proc. 4th Experimental Vibration Analysis for Civil Engineering Structures (EVACES), 2011. ,
, Matrix computations, 1996.
