, Semantics for intelligent delivery of multimedia content, pp.1366-1372, 2010.
, Semantic Coordination: A New Approach and an Application », International Semantic Web Conference, pp.130-145, 2003.
« A Comparison of String Distance Metrics for Name-Matching Tasks, pp.73-78, 2003. ,
, Searching XML documents via XML fragments, pp.151-158, 2003.
, , 2007.
WordNet: An Electronic Lexical Database, 1998. ,
Converting Relational to Object-Oriented Databases, SIGMOD Record, vol.26, issue.1, pp.53-58, 1997. ,
, Semantic Integration and Retrieval of Multimedia Metadata », 2nd European Workshop on the Integration of Knowledge, Semantic and Digital Media, pp.69-80, 2005.
an Algorithm and an Implementation of Semantic Matching, ESWS, pp.61-75, 2004. ,
Metadata Platform Specification », XMPSpecificationPart2.pdf, février, 2008. ,
« A survey of techniques for achieving metadata interoperability, ACM Comput. Surv, vol.42, issue.2, 2010. ,
, clustering XML schemas for effective integration », CIKM, pp.292-299, 2002.
Use Cases and Requirements for Ontology and API for Media Object, 2008. ,
Survey of Exploiting WordNet in Ontology Matching, IFIP AI, pp.341-350, 2008. ,
, Generic Schema Matching with Cupid, pp.49-58, 2001.
Flooding: A Versatile Graph Matching Algorithm and Its Application to Schema Matching, pp.117-128, 2002. ,
, The Clio Project: Managing Heterogeneity », SIGMOD Record, vol.30, pp.78-83, 2001.
, Enabling Semantic Mediation for Business Applications: XML-RDF, RDF-XML and XSD-RDFS transformations, pp.483-494, 2007.
, Intégration des Métadonnées 17
, , pp.598-609, 2002.
, Information Retrieval, 1979.
, Bottom-Up Merging of Ontologies, pp.225-234, 2001.
Ontology for XML Schema to Ontology Mapping Representation », iiWAS, pp.101-111, 2007. ,
