Compressed Sensing, IEEE Transactions on Information Theory, vol.52, issue.4, pp.1289-1306, 2006. ,
PhaseLift: Exact and Stable Signal Recovery from Magnitude Measurements via Convex Programming, Communications on Pure and Applied Mathematics, vol.38, issue.5, 2011. ,
DOI : 10.1002/cpa.21432
On signal reconstruction without phase, Applied and Computational Harmonic Analysis, vol.20, issue.3, pp.345-356, 2006. ,
DOI : 10.1016/j.acha.2005.07.001
URL : http://doi.org/10.1016/j.acha.2005.07.001
A practical algorithm for the determination of the phase from image and diffraction plane pictures, Optik, vol.35, issue.2, pp.237-246, 1972. ,
Compressive Phase Retrieval From Squared Output Measurements Via Semidefinite Programming*, IFAC Proceedings Volumes, vol.45, issue.16, 2011. ,
DOI : 10.3182/20120711-3-BE-2027.00415
URL : http://arxiv.org/abs/1111.6323
CPRL-An Extension of Compressive Sensing to the Phase Retrieval Problem, Neural Information Processing Systems (NIPS), 2012. ,
Sparse Signal Recovery from Quadratic Measurements via Convex Programming, SIAM Journal on Mathematical Analysis, vol.45, issue.5, pp.1-15, 2012. ,
DOI : 10.1137/120893707
Compressive sensing under matrix uncertainties: An Approximate Message Passing approach, 2011 Conference Record of the Forty Fifth Asilomar Conference on Signals, Systems and Computers (ASILOMAR), pp.804-808, 2011. ,
DOI : 10.1109/ACSSC.2011.6190118
Blind calibration for compressed sensing by convex optimization, 2012 IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), pp.2713-2716, 2012. ,
DOI : 10.1109/ICASSP.2012.6288477
URL : https://hal.archives-ouvertes.fr/hal-00658579
Compressive Phase Retrieval via Generalized Approximate Message Passing, Proceedings of Allerton Conference on Communication, Control, and Computing, 2012. ,
DOI : 10.1109/allerton.2012.6483302
URL : http://arxiv.org/abs/1405.5618
Observed universality of phase transitions in high-dimensional geometry, with implications for modern data analysis and signal processing, Philosophical transactions. Series A, Mathematical, physical, and engineering sciences, vol.367, pp.4273-93, 1906. ,
Distributed Optimization and Statistical Learning via the Alternating Direction Method of Multipliers, Machine Learning, pp.1-122, 2011. ,
DOI : 10.1561/2200000016
