Ingénierie dirigée par les modèles : quels supports à l'interopérabilité des systèmes d'information ? - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Revue des Sciences et Technologies de l'Information - Série ISI : Ingénierie des Systèmes d'Information Année : 2013
Information systems are more and more often based on aggregation of other systems that must be maintained and evolved in an agile way and without un- controlled entropy. This is not without interoperability problems! Among others, the aim of Model-Driven Engineering (MDE) is to provide solutions for interoperability issues between systems. This paper summarizes thoughts that have come up from the specific action "Interoperability of information systems and model-driven engineering: What challenges? What solutions?" supported by inforsid. We propose a summary of approaches that are based on MDE and knowledge engineering and that tackle in- teroperability issues in the industry. Open questions and limitations that raised during the meetings are also reported.
Auth13a-interop-si-JournalVersion.pdf (1.51 Mo) Télécharger le fichier
hal-00813675 , version 1 (16-04-2013)
hal-00813675 , version 2 (24-04-2013)
  • HAL Id : hal-00813675 , version 1
Annie Authosserre-Cavarero, Frédéric Bertrand, Mireille Fornarino, Philippe Collet, Hubert Dubois, et al.. Ingénierie dirigée par les modèles : quels supports à l'interopérabilité des systèmes d'information ?. Revue des Sciences et Technologies de l'Information - Série ISI : Ingénierie des Systèmes d'Information, 2013. ⟨hal-00813675v1⟩
837 Consultations
796 Téléchargements
