Abstract : Various metrics for comparing diffusion tensors have been recently proposed in the literature. We consider a broad family of metrics which is indexed by a single power parameter. A likelihood-based procedure is developed for choosing the most appropriate metric from the family for a given dataset at hand. The approach is analogous to using the Box-Cox transformation that is frequently investigated in regression analysis. The methodology is illustrated with a simulation study and an application to a real dataset of diffusion tensor images of canine hearts.
