New interface
Journal articles
Correspondence Between Simple 3-D MRI-Based Computer Models and In-Vivo EP Measurements in Swine With Chronic Infarctions
Abstract : The aim of this paper was to compare several in-vivo electrophysiological (EP) characteristics measured in a swine model of chronic infarct, with those predicted by simple 3-D MRI-based computer models built from ex-vivo scans (voxel size <1mm3 ). Specifically, we recorded electroanatomical voltage maps (EAVM) in six animals, and ECG waves during induction of arrhythmia in two of these cases. The infarct heterogeneities (dense scar and border zone) as well as fiber directions were estimated using diffusion weighted DW-MRI.We found a good correspondence (r = 0.9) between scar areas delineated on the EAVM and MRI maps. For theoretical predictions, we used a simple two-variable macroscopic model and computed the propagation of action potential after application of a train of stimuli, with location and timing replicating the stimulation protocol used in the in-vivo EP study. Simulation results are exemplified for two hearts: one with noninducible ventricular tachycardia (VT), and another with a macroreentrant VT (for the latter, the average predicted VT cycle length was 273 ms, compared to a recorded VT of 250 ms).
Complete list of metadata
Cited literature [15 references]  Display  Hide  Download
https://hal.inria.fr/hal-00813802
Contributor : Project-Team Asclepios Connect in order to contact the contributor
Submitted on : Friday, May 3, 2013 - 4:19:30 PM
Last modification on : Friday, November 18, 2022 - 9:26:39 AM
Long-term archiving on: : Sunday, August 4, 2013 - 2:50:13 AM
File
Mihaela_IeeeTBMEpreprint.pdf
Identifiers
Collections
Citation
Mihaela Pop, Maxime Sermesant, Tommasi Mansi, Eugene Crystal, Sudip Ghate, et al.. Correspondence Between Simple 3-D MRI-Based Computer Models and In-Vivo EP Measurements in Swine With Chronic Infarctions. IEEE Transactions on Biomedical Engineering, 2011, 58 (12), pp.3483-3486. ⟨10.1109/TBME.2011.2168395⟩. ⟨hal-00813802⟩
Share
Metrics
Record views
161
Files downloads
155
