New interface
Journal articles
Integration of Merged Delayed-Enhanced Magnetic Resonance Imaging and Multi-Detector Computed Tomography for the Guidance of Ventricular Tachycardia Ablation: A Pilot Study
Abstract : MDCT/MRI Fusion for the Guidance of VT Ablation. Background: Delayed enhancement (DE) MRI can assess the fibrotic substrate of scar-related VT. MDCT has the advantage of inframillimetric spatial resolution and better 3D reconstructions. We sought to evaluate the feasibility and usefulness of integrating merged MDCT/MRI data in 3D-mapping systems for structure–function assessment and multimodal guidance of VT mapping and ablation. Methods: Nine patients, including 3 ischemic cardiomyopathy (ICM), 3 nonischemic cardiomyopathy (NICM), 2 myocarditis, and 1 redo procedure for idiopathic VT, underwent MRI and MDCT before VT ablation. Merged MRI/MDCT data were integrated in 3D-mapping systems and registered to high-density endocardial and epicardial maps. Low-voltage areas (<1.5 mV) and local abnormal ventricular activities (LAVA) during sinus rhythm were correlated to DE at MRI, and wall-thinning (WT) at MDCT. Results: Endocardium and epicardium were mapped with 391 ± 388 and 1098 ± 734 points per map, respectively. Registration of MDCT allowed visualization of coronary arteries during epicardial mapping/ablation. In the idiopathic patient, integration of MRI data identified previously ablated regions. In ICM patients, both DE at MRI and WT at MDCT matched areas of low voltage (overlap 94 ± 6% and 79 ± 5%, respectively). In NICM patients, wall-thinning areas matched areas of low voltage (overlap 63 ± 21%). In patients with myocarditis, subepicardial DE matched areas of epicardial low voltage (overlap 92 ± 12%). A total number of 266 LAVA sites were found in 7/9 patients. All LAVA sites were associated to structural substrate at imaging (90% inside, 100% within 18 mm). Conclusion: The integration of merged MDCT and DEMRI data is feasible and allows combining substrate assessment with high-spatial resolution to better define structure–function relationship in scar-related VT.
Complete list of metadata
https://hal.inria.fr/hal-00813820
Contributor : Project-Team Asclepios Connect in order to contact the contributor
Submitted on : Tuesday, April 16, 2013 - 11:16:07 AM
Last modification on : Saturday, June 25, 2022 - 11:09:56 PM
Links full text
Identifiers
Collections
Citation
Hubert Cochet, Y. Komatsu, F. Sacher, A. Jadidi, D. Scherr, et al.. Integration of Merged Delayed-Enhanced Magnetic Resonance Imaging and Multi-Detector Computed Tomography for the Guidance of Ventricular Tachycardia Ablation: A Pilot Study. Journal of Cardiovascular Electrophysiology, 2013, 24 (4), pp.419-426. ⟨10.1111/jce.12052⟩. ⟨hal-00813820⟩
Share
Metrics
Record views
155
