Checking Model Transformation Refinement
Refinement is a central notion in computer science, meaning that some artefact S can be safely replaced by a refinement R, which preserves S's properties. Having available techniques and tools to check transformation refinement would enable (a) the reasoning on whether a transformation correctly implements some requirements, (b) whether a transformation implementation can be safely replaced by another one (e.g. when migrating from QVT-R to ATL), and (c) bring techniques from stepwise refinement for the engineering of model transformations. In this paper, we propose an automated methodology and tool support to check transformation refinement. Our procedure admits heterogeneous specification (e.g. PaMoMo, Tracts, OCL) and implementation languages (e.g. ATL, QVT), relying on their translation to OCL as a common representation formalism and on the use of model finding tools.
Informatique et langage [cs.CL]
