Intrinsic complexity estimates in polynomial optimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Complexity Année : 2014
Bernd Bank
  • Fonction : Auteur
  • PersonId : 940432
Joos Heintz
  • Fonction : Auteur
  • PersonId : 940434
Mohab Safey El Din
It is known that point searching in basic semialgebraic sets and the search for globally minimal points in polynomial optimization tasks can be carried out using $(s\,d)^{O(n)}$ arithmetic operations, where $n$ and $s$ are the numbers of variables and constraints and $d$ is the maximal degree of the polynomials involved.\spar \noindent We associate to each of these problems an intrinsic system degree which becomes in worst case of order $(n\,d)^{O(n)}$ and which measures the intrinsic complexity of the task under consideration.\spar \noindent We design non-uniformly deterministic or uniformly probabilistic algorithms of intrinsic, quasi-polynomial complexity which solve these problems.
opt_27_01_14.pdf (206.72 Ko) Télécharger le fichier
hal-00815123 , version 1 (18-04-2013)
hal-00815123 , version 2 (10-02-2014)
Bernd Bank, Marc Giusti, Joos Heintz, Mohab Safey El Din. Intrinsic complexity estimates in polynomial optimization. Journal of Complexity, 2014, 30 (4), pp.430-443. ⟨10.1016/j.jco.2014.02.005⟩. ⟨hal-00815123v2⟩
339 Consultations
533 Téléchargements
