Anisotropic polygonal remeshing, Proc. SIGGRAPH, 2003. ,
URL : https://hal.archives-ouvertes.fr/inria-00099624
Mixedinteger quadrangulation, Proc. SIGGRAPH, 2009. ,
Integer-grid maps for reliable quad meshing, Proc. SIGGRAPH 2013, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00862648
Quad-mesh generation and processing: A survey, Computer Graphics Forum, 2013. ,
Dual loops meshing: quality quad layouts on manifolds, ACM Trans. Graph, vol.31, issue.110, pp.1-11011, 2012. ,
Harmonic functions for quadrilateral remeshing of arbitrary manifolds, Comput. Aided Geom. Des, vol.22, issue.5, pp.392-423, 2005. ,
Spectral surface quadrangulation, ACM SIGGRAPH 2006 Papers, 2006. ,
Simulation of simplicity: a technique to cope with degenerate cases in geometric algorithms, ACM Trans. Graph, vol.9, issue.1, pp.66-104, 1990. ,
Spectral quadrangulation with orientation and alignment control, Proc. SIGGRAPH Asia, 2008. ,
Quadcover -surface parameterization using branched coverings, Computer Graphics Forum, vol.26, issue.3, pp.375-384, 2007. ,
Meshless quadrangulation by global parameterization, Computers & Graphics, vol.35, issue.5, 2011. ,
All-hex meshing using singularity-restricted field, ACM Trans. Graph, vol.31, p.6, 2012. ,
Direct anisotropic quaddominant remeshing, Proceedings of the Computer Graphics and Applications, 12th Pacific Conference, p.4, 2004. ,
Controlled-distortion constrained global parametrization, ACM Trans. Graph, vol.32, issue.4, 2013. ,
Feature-aligned t-meshes, ACM Trans. Graph, vol.29, issue.4, pp.1-11, 2010. ,
Cubecover? parameterization of 3d volumes, Computer Graphics Forum, vol.30, issue.5, pp.1397-1406, 2011. ,
Hexagonal global parameterization of arbitrary surfaces, IEEE Trans. Vis. Comput. Graph, vol.18, issue.6, pp.865-878, 2012. ,
Designing quadrangulations with discrete harmonic forms, Proc. SGP '06, 2006. ,
Surface smoothing and quality improvement of quadrilateral/hexahedral meshes with geometric flow, Proc. of the 14th IMR, B. Hanks, 2005. ,
A wavebased anisotropic quadrangulation method, Proc. SIGGRAPH, 2010. ,
