Efficient maintenance techniques for views over active documents, EDBT, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00429637
Structural joins: A primitive for efficient XML query pattern matching, ICDE, 2002. ,
Tree pattern query minimization, 2002. ,
Short (conference) version of this paper, details omitted due to double-blind reviewing ,
XML access modules: Towards physical data independence in XML databases, XIME-P, 2005. ,
Algebra-based identification of tree patterns in XQuery, FQAS, 2006. ,
A Framework for Using Materialized XPath Views in XML Query Processing, VLDB, 2004. ,
DOI : 10.1016/B978-012088469-8.50009-7
Incremental validation of XML documents, ACM Transactions on Database Systems, vol.29, issue.4, 2004. ,
DOI : 10.1145/1042046.1042050
Update semantics of relational views, ACM Trans. Database Syst, vol.6, issue.4, 1981. ,
Verification of tree updates for optimization Schema-based independence analysis for XML updates Destabilizers and independence of XML updates, CAV VLDB, 2005. ,
Detecting XML query-update independence, Bases de Données Avancées, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00542526
Incremental XPath evaluation, ICDT, 2009. ,
Relational lenses, Proceedings of the twenty-fifth ACM SIGMOD-SIGACT-SIGART symposium on Principles of database systems , PODS '06, 2006. ,
DOI : 10.1145/1142351.1142399
Dynamic reasoning on XML updates, Proceedings of the 14th International Conference on Extending Database Technology, pp.165-176, 2011. ,
An efficient XPath query processor for XML streams, ICDE, 2006. ,
Updating Recursive XML Views of Relations, J. Comput. Sci. Technol, vol.23, issue.4, 2008. ,
Order-sensitive view maintenance of materialized XQuery views, 2003. ,
Incremental maintenance of materialized XQuery views, ICDE, 2006. ,
An algebraic approach to view maintenance for XQuery, PLAN-X workshop, 2008. ,
Cost based plan selection for XPath, SIGMOD, pp.603-614, 2009. ,
Properties and update semantics of consistent views Maintaining views incrementally, SIGMOD, 1988. ,
Query caching and view selection for XML databases, VLDB, 2005. ,
Efficient XQuery rewriting using multiple views, ICDE, 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00544366
Incremental maintenance for materialized XPath/XSLT views, WWW, 2005. ,
Rewriting nested XML queries using nested views, SIGMOD, 2006. ,
XSKETCH synopses for XML data graphs, ACM Trans. Database Syst, vol.31, issue.3, pp.1014-1063, 2006. ,
Maintaining XPath views in loosely coupled systems, VLDB, 2006. ,
Incremental maintenance of pathexpression views, SIGMOD, 2005. ,
XMark, VLDB, 2002. ,
DOI : 10.1016/B978-155860869-6/50096-2
Multiple materialized view selection for XPath query rewriting, ICDE, 2008. ,
Structural join order selection for XML query optimization, ICDE. XPath 2.0 1999. XML Path Language, 2003. ,
The XML Query Language, 2009. ,
DDE: from Dewey to a fully dynamic XML labeling scheme, SIGMOD, 2009. ,
Rewriting XPath queries using materialized views, VLDB, 2005. ,
On workload characterization of relational database environments, IEEE Trans. Software Eng, vol.18, issue.4, pp.347-355, 1992. ,
