Consensus and Cooperation in Networked Multi-Agent Systems, Proc. of the IEEE, pp.215-233, 2007. ,
DOI : 10.1109/JPROC.2006.887293
Cooperative Diversity in Wireless Networks: Efficient Protocols and Outage Behavior, IEEE Transactions on Information Theory, vol.50, issue.12, pp.3062-3080, 2004. ,
DOI : 10.1109/TIT.2004.838089
Cooperative communications and networking, 2009. ,
Tensor-Based Channel Estimation and Iterative Refinements for Two-Way Relaying With Multiple Antennas and Spatial Reuse, IEEE Transactions on Signal Processing, vol.58, issue.11, pp.5720-5735, 2010. ,
DOI : 10.1109/TSP.2010.2062179
Distributed parafac based DS-CDMA blind receiver for wireless sensor networks, 2010 IEEE 11th International Workshop on Signal Processing Advances in Wireless Communications (SPAWC), 2010. ,
DOI : 10.1109/SPAWC.2010.5671048
URL : https://hal.archives-ouvertes.fr/hal-00480584
Distributed Khatri-Rao space-time coding and decoding for cooperative networks, Proc. EUSIPCO 2011, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00598662
Foundations of the PARAFAC procedure: Models and conditions for an " explanatory " multimodal factor analysis, UCLA Working Papers in Phonetics, 1970. ,
Modeling multi-way data with linearly dependent loadings, Journal of Chemometrics, vol.16, issue.7-8, pp.324-340, 2009. ,
DOI : 10.1002/cem.1206
Blind PARAFAC receivers for DS-CDMA systems, IEEE Transactions on Signal Processing, vol.48, issue.3, pp.810-823, 2000. ,
DOI : 10.1109/78.824675
PARAFAC-based unified tensor modeling for wireless communication systems with application to blind multiuser equalization, Signal Processing, vol.87, issue.2, pp.337-351, 2007. ,
DOI : 10.1016/j.sigpro.2005.12.014
URL : https://hal.archives-ouvertes.fr/hal-00417636
A Block Component Model-Based Blind DS-CDMA Receiver, IEEE Transactions on Signal Processing, vol.56, issue.11, pp.5567-5579, 2008. ,
DOI : 10.1109/TSP.2008.926982
Blind equalization of nonlinear channels using a tensor decomposition with code/space/time diversities, Signal Processing, vol.89, issue.2, pp.133-143, 2009. ,
DOI : 10.1016/j.sigpro.2008.07.016
URL : https://hal.archives-ouvertes.fr/hal-00417609
Unified Tensor Modeling for Blind Receivers in Multiuser Uplink Cooperative Systems, IEEE Signal Processing Letters, vol.19, issue.5, pp.247-250, 2012. ,
DOI : 10.1109/LSP.2012.2188510
A constrained factor decomposition with application to MIMO antenna systems Three-way arrays: rank and uniqueness of trilinear decompositions, with application to arithmetic complexity and statistics Uni-mode and partial uniqueness conditions for CANDECOMP/PARAFAC of three-way arrays with linearly dependent loadings, IEEE Trans. Signal Process. Linear Algebra Applicat. SIAM J. Matrix Anal. Appl, vol.56, issue.33 1, pp.2429-2442, 1977. ,
Multi-way analysis: application in chemical sciences, 2004. ,
DOI : 10.1002/0470012110
