Conference papers
Surface reconstruction of the surgical field from stereoscopic microscope views in neurosurgery
Abstract : We present a technique to reconstruct the surface of the surgical field during neurosurgery. The images are taken with a stereo camera mounted on a surgical microscope, which is part of a neuronavigation system. We use an intensity-based method to calculate a dense disparity map over the whole image extend. Correspondences are established by exploiting the epipolar ge- ometry and comparing image intensities along corresponding epipolar lines. The method does not require a strong calibration. Only the colineation denoted by the fundamental matrix, which maps corresponding epipolar lines from one image to the other, has to be known. The results show that our method is able to reconstruct the surface of the surgical field upto a few areas. It is limited at points of specular reflections of the wet brain surface and points of uniform texture.
Document type :
Conference papers
Complete list of metadata
Cited literature [11 references]  Display  Hide  Download
https://hal.inria.fr/hal-00816696
Contributor : Frédéric Devernay Connect in order to contact the contributor
Submitted on : Monday, April 22, 2013 - 5:22:58 PM
Last modification on : Friday, February 4, 2022 - 3:23:44 AM
Long-term archiving on: : Monday, April 3, 2017 - 8:25:37 AM
File
car2001.pdf
Identifiers
Collections
Citation
Oliver J. Fleig, Frédéric Devernay, Jean-Marie Scarabin, Pierre Jannin. Surface reconstruction of the surgical field from stereoscopic microscope views in neurosurgery. Computer Assisted Radiology and Surgery, 2001, Berlin, Germany. pp.268-274, ⟨10.1016/S0531-5131(01)00054-1⟩. ⟨hal-00816696⟩
Share
Metrics
Record views
193
Files downloads
233
