Improving correlation-based DEMs by image warping and facade correlation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2000
We present in this article a system which improves a DEM. The method reconstructs all the facades of the build- ing and then, corrects the initial DEM by deleting the points of the roofs which pass over the boundaries defined by the facades. We correct the shapes of the buildings with the initial photographs to have sharp contours. The proposed approach does not use any a priori information about the orientation of the facades and the shape of the buildings. We present results with synthetic and real images.
cvpr00.pdf (942.96 Ko) Télécharger le fichier
hal-00816698 , version 1 (22-04-2013)
Christophe Vestri, Frédéric Devernay. Improving correlation-based DEMs by image warping and facade correlation. CVPR - International Conference on Computer Vision and Pattern Recognition - 2000, 2000, Hilton Head, United States. pp.438 - 443, ⟨10.1109/CVPR.2000.855852⟩. ⟨hal-00816698⟩
148 Consultations
128 Téléchargements
