New interface
Conference papers
Computing Differential Properties of 3-D Shapes from Stereoscopic Images without 3-D Models
Frédéric Devernay 1 Olivier Faugeras 1
1 ROBOTVIS - Computer Vision and Robotics
CRISAM - Inria Sophia Antipolis - Méditerranée
Abstract : We are considering the problem of recovering the three-dimensional geometry of a scene from binocular stereo disparity. Once a dense disparity map has been computed from a stereo pair of images, one often needs to calculate some local differential properties of the corresponding 3-D surface such as orientation or curvatures. The usual approach is to build a 3-D reconstruction of the surface(s) from which all shape properties will then be derived without ever going back to the original images. In this paper, we depart from this paradigm and propose to use the images directly to compute the shape properties. We thus propose a new method extending the classical correlation method to estimate accurately both the disparity and its derivatives directly from the image data. We then relate those derivatives to differential properties of the surface such as orientation and curvatures.
Document type :
Conference papers
Complete list of metadata
Cited literature [12 references]  Display  Hide  Download
https://hal.inria.fr/hal-00816702
Contributor : Frédéric Devernay Connect in order to contact the contributor
Submitted on : Monday, April 22, 2013 - 5:38:15 PM
Last modification on : Friday, February 4, 2022 - 3:24:17 AM
Long-term archiving on: : Tuesday, July 23, 2013 - 4:14:35 AM
File
cvpr94.pdf
Identifiers
Collections
Citation
Frédéric Devernay, Olivier Faugeras. Computing Differential Properties of 3-D Shapes from Stereoscopic Images without 3-D Models. CVPR - International Conference on Computer Vision and Pattern Recognition - 1994, 1994, Seattle, United States. pp.208 - 213, ⟨10.1109/CVPR.1994.323831⟩. ⟨hal-00816702⟩
Share
Metrics
Record views
189
Files downloads
178
