The JPEG still picture compression standard, Communications of the ACM, vol.34, issue.4, pp.30-44, 1991. ,
DOI : 10.1145/103085.103089
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.176.7884
Handbook of blind source separation. Independent component analysis and applications. Academic press, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00460653
Natural image statistics ? a probabilistic approach to early computational vision, 2009. ,
Validity of the Independence Assumption for the Separation of Instantaneous and Convolutive Mixtures of Speech and Music Sources, Proc. of ICA, pp.613-620, 2009. ,
DOI : 10.1016/j.sigpro.2006.02.032
URL : https://hal.archives-ouvertes.fr/inria-00544163
ICA based algorithms for computing optimal 1-D linear block transforms in variable high-rate source coding, Signal Processing, vol.88, issue.2, pp.268-283, 2008. ,
DOI : 10.1016/j.sigpro.2007.07.017
URL : https://hal.archives-ouvertes.fr/hal-00278351
Improved low bitrate audio compression using ICA without psychoacoustic modeling, Proc. of ICASSP, pp.461-464, 2003. ,
DOI : 10.1109/icassp.2003.1200006
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.14.7243
A sinusoidal voice over packet coder tailored for the frame-erasure channel, IEEE Transactions on Speech and Audio Processing, vol.13, issue.5, pp.787-798, 2005. ,
DOI : 10.1109/TSA.2005.851913
Iklax: a new musical audio format for interactive music, Proc. of ICMC, pp.85-88, 2008. ,
Oracle estimators for the benchmarking of source separation algorithms, Signal Processing, vol.87, issue.8, pp.1933-1950, 2007. ,
DOI : 10.1016/j.sigpro.2007.01.016
URL : https://hal.archives-ouvertes.fr/inria-00545156
On the disjointess of sources in music using different time-frequency representations, 2011 IEEE Workshop on Applications of Signal Processing to Audio and Acoustics (WASPAA), pp.261-264, 2011. ,
DOI : 10.1109/ASPAA.2011.6082321
Independent component analysis for brain fMRI does not select for independence, Proceedings of the National Academy of Sciences, vol.106, issue.26, pp.10415-10422, 2009. ,
DOI : 10.1073/pnas.0903525106
URL : http://www.ncbi.nlm.nih.gov/pmc/articles/PMC2705604
Blind separation of instantaneous mixtures of nonstationary sources, IEEE Transactions on Signal Processing, vol.49, issue.9, pp.1837-1848, 2001. ,
DOI : 10.1109/78.942614
The 2008 Signal Separation Evaluation Campaign: A Community-Based Approach to Large-Scale Evaluation, Proc. of ICA, pp.734-741, 2009. ,
DOI : 10.1109/TASL.2007.899176
URL : https://hal.archives-ouvertes.fr/inria-00544168
Informed audio source separation from compressed linear stereo mixtures, Proc. of AES Int. Conf, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00695724
