Argumentation over Ontology Correspondences in MAS
In order to support semantic interoperation in open environments, where agents can dynamically join or leave and no prior assumption can be made on the ontologies to align, the different agents involved need to agree on the semantics of the terms used during the interoperation. Reaching this agreement can only come through some sort of negotiation process. Indeed, agents will differ in the domain ontologies they commit to; and their perception of the world, and hence the choice of vocabulary used to represent concepts. We propose an approach for supporting the creation and exchange of different arguments, that support or reject possible correspondences. Each agent can decide, according to its preferences, whether to accept or refuse a candidate correspondence. The proposed framework considers arguments and propositions that are specific to the matching task and are based on the ontology semantics. This argumentation framework relies on a formal argument manipulation schema and on an encoding of the agents' preferences between particular kinds of arguments.
