Consistency restoration and explanations in dynamic cspsapplication to configuration, Artificial Intelligence, vol.135, issue.12, 2002. ,
From restricted path consistency to max-restricted path consistency, CP, pp.312-326, 1997. ,
DOI : 10.1007/BFb0017448
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.25.5837
Interactive configuration using constraint satisfaction techniques la construction et la maintenance d'un CSP est plus facile que celles d'un ensemble de r` egles ; on ne peut attribuer de sourcè a une r` egle (marketing, restriction technique) alors qu'on le peut pour une contrainte ; CSP continus, Proceedings of PACT-96, pp.37-44, 1996. ,
Super solutions in constraint programming. Integration of AI and OR Techniques in Constraint Programming for Combinatorial Optimization Problems, pp.157-172, 2004. ,
Product Configuration Management in ICT Companies: The Practitioners??? Perspective, Technology and Investment, pp.0-0, 2011. ,
DOI : 10.4236/ti.2011.24028
A classification and constraintbased framework for configuration, Artificial Intelligence for Engineering Design Analysis and Manufacturing, vol.12, pp.383-397, 1998. ,
Dynamic constraint satisfaction problemsPremì ere définition des DynamicCSP, Proceedings of AAAI'90, pp.25-32, 1990. ,
Towards a generic model of configuraton tasks, IJCAI, pp.1395-1401, 1989. ,
Good old discrete relaxation, 1988. ,
URL : https://hal.archives-ouvertes.fr/inria-00548479
Explications conviviales pour la programmation par contraintes, JFPLC, p.105, 2002. ,
URL : https://hal.archives-ouvertes.fr/hal-00869119
Configuration as composite constraint satisfaction Composite CSP = CSP récursifrécursifà qui on ajoute l'´ etat " inactif, AI and Manufacturing Research Planning Workshop, pp.153-161, 1996. ,
Product configuration frameworks-a survey, IEEE Intelligent Systems, vol.13, issue.4, pp.42-49, 1998. ,
DOI : 10.1109/5254.708432
Generative constraint-based configuration of large technical
systems, AI EDAM, vol.12, issue.04, pp.307-320, 1998. ,
DOI : 10.1017/S0890060498124046
On reformulation of constraint satisfaction problems (extended version), Handbook of Constraint Programming Artificial Intelligence. Citeseer, pp.837-874, 1998. ,
