The IO and OI hierarchies revisited - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We study languages of lambda-terms generated by IO and OI unsafe grammars. These languages can be used to model meaning representations in the formal semantics of natural languages following the tradition of Montague. Using techniques pertaining to the denotational semantics of the simply typed lambda-calculus, we show that the emptiness and membership problems for both types of grammars are decidable. In the course of the proof of the decidability results for OI, we identify a decidable variant of the lambda-definability problem, and prove a stronger form of Statman's finite completeness Theorem.
io_and_oi_revisited.pdf (369.38 Ko) Télécharger le fichier
hal-00818069 , version 1 (25-04-2013)
  • HAL Id : hal-00818069 , version 1
Gregory M. Kobele, Sylvain Salvati. The IO and OI hierarchies revisited. ICALP (2), Jul 2013, Riga, Latvia. ⟨hal-00818069⟩
146 Consultations
254 Téléchargements
