Scene Text Recognition using Higher Order Language Priors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The problem of recognizing text in images taken in the wild has gained significant attention from the computer vision community in recent years. Contrary to recognition of printed documents, recognizing scene text is a challenging problem. We focus on the problem of recognizing text extracted from natural scene images and the web. Significant attempts have been made to address this problem in the recent past. However, many of these works benefit from the availability of strong context, which naturally limits their applicability. In this work we present a framework that uses a higher order prior computed from an English dictionary to recognize a word, which may or may not be a part of the dictionary. We show experimental results on publicly available datasets. Furthermore, we introduce a large challenging word dataset with five thousand words to evaluate various steps of our method exhaustively. The main contributions of this work are: (1) We present a framework, which incorporates higher order statistical language models to recognize words in an unconstrained manner (i.e. we overcome the need for restricted word lists, and instead use an English dictionary to compute the priors). (2) We achieve significant improvement (more than 20%) in word recognition accuracies without using a restricted word list. (3) We introduce a large word recognition dataset (atleast 5 times larger than other public datasets) with character level annotation and benchmark it.
mishra12a.pdf (272.95 Ko) Télécharger le fichier
hal-00818183 , version 1 (17-10-2013)
Anand Mishra, Karteek Alahari, C.V. Jawahar. Scene Text Recognition using Higher Order Language Priors. BMVC - British Machine Vision Conference, Sep 2012, Surrey, United Kingdom. ⟨10.5244/C.26.127⟩. ⟨hal-00818183⟩
1467 Consultations
1156 Téléchargements
