Intensive Surrogate Model Exploitation in Self-adaptive Surrogate-assisted CMA-ES (saACM-ES) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents a new mechanism for a better exploitation of surrogate models in the framework of Evolution Strategies (ESs). This mechanism is instantiated here on the self-adaptive surrogate-assisted Covariance Matrix Adaptation Evolution Strategy (saACM-ES), a recently proposed surrogate-assisted variant of CMA-ES. As well as in the original saACM-ES, the expensive function is optimized by exploiting the surrogate model, whose hyper-parameters are also optimized online. The main novelty concerns a more intensive exploitation of the surrogate model by using much larger population sizes for its optimization. The new variant of saACM-ES significantly improves the original saACM-ES and further increases the speed-up compared to the CMA-ES, especially on unimodal functions (e.g., on 20-dimensional Rotated Ellipsoid, saACM-ES is 6 times faster than aCMA-ES and almost by one order of magnitude faster than CMA-ES). The empirical validation on the BBOB-2013 noiseless testbed demonstrates the efficiency and the robustness of the proposed mechanism.
gecco2013.pdf (1.04 Mo) Télécharger le fichier
hal-00818595 , version 1 (28-04-2013)
  • HAL Id : hal-00818595 , version 1
Ilya Loshchilov, Marc Schoenauer, Michèle Sebag. Intensive Surrogate Model Exploitation in Self-adaptive Surrogate-assisted CMA-ES (saACM-ES). Genetic and Evolutionary Computation Conference (GECCO 2013), Jul 2013, Amsterdam, Netherlands. pp.439-446. ⟨hal-00818595⟩
237 Consultations
453 Téléchargements
