Reports
Co-Scheduling Algorithms for High-Throughput Workload Execution
Abstract : This paper investigates co-scheduling algorithms for processing a set of parallel applications. Instead of executing each application one by one, using a maximum degree of parallelism for each of them, we aim at scheduling several applications concurrently. We partition the original application set into a series of packs, which are executed one by one. A pack comprises several applications, each of them with an assigned number of processors, with the constraint that the total number of processors assigned within a pack does not exceed the maximum number of available processors. The objective is to determine a partition into packs, and an assignment of processors to applications, that minimize the sum of the execution times of the packs. We thoroughly study the complexity of this optimization problem, and propose several heuristics that exhibit very good performance on a variety of workloads, whose application execution times model profiles of parallel scientific codes. We show that co-scheduling leads to to faster workload completion time and to faster response times on average (hence increasing system throughput and saving energy), for significant benefits over traditional scheduling from both the user and system perspectives.
Complete list of metadata
Cited literature [22 references]  Display  Hide  Download
https://hal.inria.fr/hal-00819036
Contributor : Guillaume Pallez (Aupy) Connect in order to contact the contributor
Submitted on : Wednesday, May 8, 2013 - 10:32:47 AM
Last modification on : Friday, September 30, 2022 - 4:12:04 AM
Long-term archiving on: : Tuesday, April 4, 2017 - 1:44:15 AM
File
RR-8293.pdf
Identifiers
  • HAL Id : hal-00819036, version 1
Collections
Citation
Guillaume Aupy, Manu Shantharam, Anne Benoit, Yves Robert, Padma Raghavan. Co-Scheduling Algorithms for High-Throughput Workload Execution. [Research Report] RR-8293, INRIA. 2013, pp.21. ⟨hal-00819036⟩
Share
Metrics
Record views
200
Files downloads
143
