Unbiased estimation of a sinusoid in colored noise via adapted notch filters, Automatica, vol.33, issue.2, pp.209-215, 1997. ,
DOI : 10.1016/S0005-1098(96)00145-8
On the parametrization and design of an extended Kalman filter frequency tracker, IEEE Transactions on Automatic Control, vol.45, issue.9, pp.1718-1724, 2000. ,
DOI : 10.1109/9.880631
Switched Algorithm for Frequency Estimation with Noise Rejection, IEEE Transactions on Automatic Control, vol.57, issue.9 ,
DOI : 10.1109/TAC.2012.2186685
Adaptive algorithms for the rejection of sinusoidal disturbances with unknown frequency, Proc. 13th IFAC World Conf, 1996. ,
DOI : 10.1016/S0005-1098(97)00149-0
Exact maximum likelihood parameter estimation of superimposed exponential signals in noise, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.34, issue.5, pp.1081-1089, 1986. ,
DOI : 10.1109/TASSP.1986.1164949
Hybrid Observer for Global Frequency Estimation of Saturated Signals, IEEE Transactions on Automatic Control, vol.54, issue.10, pp.2461-2464, 2009. ,
DOI : 10.1109/TAC.2009.2029395
A hybrid observer for frequency estimation of saturated multi-frequency signals, IEEE Conference on Decision and Control and European Control Conference, pp.2577-2582, 2011. ,
DOI : 10.1109/CDC.2011.6160889
Integration over finite sets, Nonstandard Analysis in, pp.195-204, 1995. ,
A new IIR adaptive notch filter, Signal Process, pp.1648-1655, 2006. ,
Algèbres enveloppantes, Gauthier-Villars, 1974. ,
Maximum likehood estimation of sinusoidal parameteres using a gloabal optimisation algorithm, Ninth Asilomar Conference on Signals, Systems and Computers, pp.1167-1171, 1995. ,
Consistency of subspace methods for signals with almost-periodic components, Automatica, vol.48, issue.3, pp.514-520, 2012. ,
DOI : 10.1016/j.automatica.2011.08.059
Multi-sinusoidal signal estimation by an adaptive SOGI-filters bank, 15th IFAC Symposium on System Identification, 2009. ,
DOI : 10.3182/20090706-3-FR-2004.00066
Analyse non standard du bruit, Comptes Rendus Mathematique, vol.342, issue.10, pp.797-802, 2006. ,
DOI : 10.1016/j.crma.2006.02.037
URL : https://hal.archives-ouvertes.fr/inria-00001134
Critique du rapport signaì a bruit en communications numériques, pp.419-429, 2008. ,
Algebraic change-point detection, Applicable Algebra in Engineering, Communication and Computing, vol.83, issue.2, pp.131-143, 2010. ,
DOI : 10.1007/s00200-010-0119-z
URL : https://hal.archives-ouvertes.fr/inria-00439226
Questioning some paradigms of signal processing via concrete examples, Algebraic Methods in Flatness, Signal Processing and State Estimation, Editorial Lagares, pp.1-21, 2003. ,
URL : https://hal.archives-ouvertes.fr/inria-00001059
An algebraic framework for linear identification, ESAIM: Control, Optimisation and Calculus of Variations, vol.9, pp.151-168, 2003. ,
DOI : 10.1051/cocv:2003008
Closed-loop parametric identification for continuous-time linear systems via new algebraic techniques, in H. from Sampled Data, pp.362-391, 2008. ,
Non-linear estimation is easy, International Journal of Modelling, Identification and Control, vol.4, issue.1, pp.12-27, 2008. ,
DOI : 10.1504/IJMIC.2008.020996
URL : https://hal.archives-ouvertes.fr/inria-00158855
Analysis and performance evaluation of an adaptive notch filter, IEEE Transactions on Information Theory, vol.30, issue.2, pp.283-295, 1984. ,
DOI : 10.1109/TIT.1984.1056887
Adaptive Filter Theory, 1991. ,
A globally convergent frequency estimator, IEEE Transactions on Automatic Control, vol.44, issue.4, pp.698-713, 1999. ,
DOI : 10.1109/9.754808
On the consistency of Prony's method and related algorithms, J. Comput. Graph. Statist, vol.1, pp.329-349, 1992. ,
Spectrum analysis-a modern perspective, Proc. IEEE, pp.1380-1419, 1981. ,
Conditions for stability of the extended Kalman filter and their application to the frequency tracking problem, Mathematics of Control, Signals and Systems, vol.38, issue.1, pp.1-26, 1995. ,
DOI : 10.1007/BF01212364
Design of an extended Kalman filter frequency tracker, IEEE Trans. Signal Process, vol.44, issue.3, pp.739-742, 1996. ,
An extended Kalman filter frequency tracker for high-noise environments, IEEE Transactions on Signal Processing, vol.44, issue.2, pp.431-434, 1996. ,
DOI : 10.1109/78.485940
Strong consistency of the contraction mapping method for frequency estimation, IEEE Transactions on Information Theory, vol.39, issue.3, pp.989-998, 1993. ,
DOI : 10.1109/18.256505
Fundamental frequency estimation based on the joint time-frequency analysis of harmonic spectral structure, IEEE Trans. Acoust., Speech, Signal Process, vol.9, issue.6, pp.609-621, 2001. ,
An error analysis in the algebraic estimation of a noisy sinusoidal signal, 2008 16th Mediterranean Conference on Control and Automation, 2008. ,
DOI : 10.1109/MED.2008.4602161
URL : https://hal.archives-ouvertes.fr/inria-00300234
Differentiation by integration with Jacobi polynomials, Journal of Computational and Applied Mathematics, vol.235, issue.9, pp.3015-3032, 2011. ,
DOI : 10.1016/j.cam.2010.12.023
URL : https://hal.archives-ouvertes.fr/inria-00550160
Error analysis of a Jacobi derivative estimators for noisy signals, Numerical Algo, pp.53-83, 2011. ,
A revised look at numerical differentiation with an application to nonlinear feedback control, 2007 Mediterranean Conference on Control & Automation, 2007. ,
DOI : 10.1109/MED.2007.4433728
URL : https://hal.archives-ouvertes.fr/inria-00142588
Parameter estimation for signals described by differential equations, Applicable Analysis, vol.26, issue.1, pp.29-52, 2009. ,
Join and M. Fliess, Numerical differentiation with annihilators in noisy environment, Numerical Algo, pp.439-467, 2009. ,
An Adaptive Notch Filter for Frequency Estimation of a Periodic Signal, IEEE Transactions on Automatic Control, vol.49, issue.2, pp.314-318, 2004. ,
DOI : 10.1109/TAC.2003.821414
Channel estimation for non-ideal OFDM systems, IEEE Transactions on Communications, vol.58, issue.1, pp.146-156, 2010. ,
DOI : 10.1109/TCOMM.2010.01.070650
An Algebraic Receiver for Full Response CPM Demodulation, VI Int, Telecom. Symp. (ITS2006), 2006. ,
A Modified Prony Algorithm for Exponential Function Fitting, SIAM Journal on Scientific Computing, vol.16, issue.1, pp.119-138, 1995. ,
DOI : 10.1137/0916008
An algebraic approach for human posture estimation in the sagittal plane using accelerometer noisy signal, in proc, 2012. ,
Essai exprimental et analytique : sur les lois de la dilatabilité de fluidesélastiquesfluides´fluidesélastiques et sur celles de la force expansive de la vapeur de l'eau et de la vapeur de l'alcooì a différentes températures, pp.24-76 ,
Adaptive notch filtering for the retrieval of sinusoids in noise, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.32, issue.4, pp.791-802, 1984. ,
DOI : 10.1109/TASSP.1984.1164398
Adaptive IIR Filtering in Signal Processing and Control, 1995. ,
ESPRIT-estimation of signal parameters via rotational invariance techniques, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.37, issue.7, pp.984-995, 1989. ,
DOI : 10.1109/29.32276
A generalized weighted linear predictor frequency estimation approach for a complex sinusoid, IEEE Transactions on Signal Processing, vol.54, issue.4, pp.1304-1315, 2006. ,
DOI : 10.1109/TSP.2005.863119
Performance analysis of an adaptive notch filter with constrained poles and zeros, IEEE Transactions on Acoustics, Speech, and Signal Processing, vol.36, issue.6, pp.911-919, 1988. ,
DOI : 10.1109/29.1602
List of references on spectral line analysis, Signal Processing, vol.31, issue.3, pp.329-340, 1993. ,
DOI : 10.1016/0165-1684(93)90090-W
An algebraic frequency estimator for a biased and noisy sinusoidal signal, Signal Processing, vol.87, issue.6, pp.1188-1201, 2007. ,
DOI : 10.1016/j.sigpro.2006.10.006
A fast on-line frequency estimator of lightly damped vibrations in flexible structures, Journal of Sound and Vibration, vol.307, issue.1-2, pp.365-378, 2007. ,
DOI : 10.1016/j.jsv.2007.07.005
On-line frequency and damping estimation in a single-link flexible manipulator based on algebraic identification, 2008. ,
On the algebraic identification of the frequencies, amplitudes and phases of two sinusoidal signals from their noisy sum, International Journal of Control, vol.339, issue.3, pp.507-518, 2008. ,
DOI : 10.1016/j.sigpro.2004.05.008
Estimation algébrique des paramètres intrinsèques d'un signal sinuso¨?dalsinuso¨?dal biaisé en environnement bruité, Proc. Gretsi, 5-9 septembre, 2011. ,
Algebraic parameter estimation of a biased sinusoidal waveform signal from noisy data, 16th IFAC Symposium on System Identification, 2012. ,
DOI : 10.3182/20120711-3-BE-2027.00393
URL : https://hal.archives-ouvertes.fr/hal-00685067
Global frequency estimation using adaptive identifiers, IEEE Transactions on Automatic Control, vol.47, issue.7, pp.1188-1193, 2002. ,
DOI : 10.1109/TAC.2002.800670
