Implementing the cylindrical algebraic decomposition within the Coq system
The Coq system is a Curry-Howard based proof assistant. Therefore, it contains a full functional, strongly typed programming language, which can be used to enhance the system with powerful automation tools through the implementation of reflexive tactics. We present the implementation of a cylindrical algebraic decomposition algorithm within the Coq system, whose certification leads to a proof producing decision procedure for the first-order theory of real numbers.
