Robin based semi-implicit coupling in fluidstructure interaction: Stability analysis and numerics, SIAM J. Sci. Comput, issue.6, pp.314041-4065, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00361284
Fluid???structure partitioned procedures based on Robin transmission conditions, Journal of Computational Physics, vol.227, issue.14, pp.7027-7051, 2008. ,
DOI : 10.1016/j.jcp.2008.04.006
Isogeometric fluid-structure interaction: theory, algorithms, and computations, Computational Mechanics, vol.196, issue.2, pp.3-37, 2008. ,
DOI : 10.1007/s00466-008-0315-x
Penalty free Nitsche method for interface problems in computational mechanics ,
A Penalty-Free Nonsymmetric Nitsche-Type Method for the Weak Imposition of Boundary Conditions, SIAM Journal on Numerical Analysis, vol.50, issue.4, pp.1959-1981, 2012. ,
DOI : 10.1137/10081784X
Stabilization of explicit coupling in fluid???structure interaction involving fluid incompressibility, Computer Methods in Applied Mechanics and Engineering, vol.198, issue.5-8, pp.5-8766, 2009. ,
DOI : 10.1016/j.cma.2008.10.012
URL : https://hal.archives-ouvertes.fr/inria-00247409
Added-mass effect in the design of partitioned algorithms for fluid???structure problems, Computer Methods in Applied Mechanics and Engineering, vol.194, issue.42-44, pp.42-444506, 2005. ,
DOI : 10.1016/j.cma.2004.12.005
URL : https://hal.archives-ouvertes.fr/hal-00695954
Parallel Algorithms for Fluid-Structure Interaction Problems in Haemodynamics, SIAM Journal on Scientific Computing, vol.33, issue.4, pp.1598-1622, 2011. ,
DOI : 10.1137/090772836
Fluid-structure algorithms based on Steklov-Poincaré operators Dettmer and D. Peri?. A computational framework for fluid-rigid body interaction: finite element formulation and applications, Comput. Methods Appl. Mech. Engrg. Comput. Methods Appl. Mech. Engrg, vol.195, issue.195, pp.41-435797, 2006. ,
Robust and provably second-order explicit-explicit and implicit-explicit staggered time-integrators for highly non-linear compressible fluid-structure interaction problems, International Journal for Numerical Methods in Engineering, vol.125, issue.1, pp.73-107, 2010. ,
DOI : 10.1002/nme.2883
Provably second-order time-accurate looselycoupled solution algorithms for transient nonlinear aeroelasticity, Comput. Methods Appl. Mech. Engrg, vol.195, pp.17-181973, 2006. ,
Coupling schemes for incompressible fluid-structure interaction: implicit, semi-implicit and explicit, SeMA Journal, vol.40, issue.12, pp.59-108, 2011. ,
DOI : 10.1007/BF03322593
Incremental displacement-correction schemes for incompressible fluid-structure interaction, Numerische Mathematik, vol.17, issue.6, pp.21-65, 2013. ,
DOI : 10.1007/s00211-012-0481-9
A projection semi-implicit scheme for the coupling of an elastic structure with an incompressible fluid, International Journal for Numerical Methods in Engineering, vol.9, issue.4, pp.794-821, 2007. ,
DOI : 10.1002/nme.1792
A Newton method using exact jacobians for solving fluid???structure coupling, Computers & Structures, vol.83, issue.2-3, pp.127-142, 2005. ,
DOI : 10.1016/j.compstruc.2004.04.021
Displacement-velocity correction schemes for incompressible fluid???structure interaction, Comptes Rendus Mathematique, vol.349, issue.17-18, pp.17-181011, 2011. ,
DOI : 10.1016/j.crma.2011.08.004
Explicit Robin???Neumann schemes for the coupling of incompressible fluids with thin-walled structures, Computer Methods in Applied Mechanics and Engineering, vol.267, 2013. ,
DOI : 10.1016/j.cma.2013.09.020
On the coupling of 3D and 1D Navier???Stokes equations for flow problems in compliant vessels, Computer Methods in Applied Mechanics and Engineering, vol.191, issue.6-7, pp.6-7561, 2001. ,
DOI : 10.1016/S0045-7825(01)00302-4
URL : https://hal.archives-ouvertes.fr/hal-00691928
of Modeling, Simulation and Applications, Cardiovascular Mathematics. Modeling and simulation of the circulatory system, 2009. ,
Artificial added mass instabilities in sequential staggered coupling of nonlinear structures and incompressible viscous flows, Computer Methods in Applied Mechanics and Engineering, vol.196, issue.7, pp.1278-1293, 2007. ,
DOI : 10.1016/j.cma.2006.09.002
Truly monolithic algebraic multigrid for fluid-structure interaction, International Journal for Numerical Methods in Engineering, vol.33, issue.2, pp.987-1016, 2011. ,
DOI : 10.1002/nme.3001
A Quasi-Newton Algorithm Based on a Reduced Model for Fluid-Structure Interaction Problems in Blood Flows, ESAIM: Mathematical Modelling and Numerical Analysis, vol.37, issue.4, pp.631-648, 2003. ,
DOI : 10.1051/m2an:2003049
URL : https://hal.archives-ouvertes.fr/hal-00694625
Stable loosely-coupled-type algorithm for fluid???structure interaction in blood flow, Journal of Computational Physics, vol.228, issue.18, pp.6916-6937, 2009. ,
DOI : 10.1016/j.jcp.2009.06.007
Abstract, Communications in Computational Physics, vol.19, issue.02, pp.337-377, 2012. ,
DOI : 10.1006/jcph.1999.6356
Fixed-point fluid???structure interaction solvers with dynamic relaxation, Computational Mechanics, vol.35, issue.6???8, pp.61-72, 2008. ,
DOI : 10.1007/s00466-008-0255-5
Fluid structure interaction with large structural displacements, Comput. Meth. Appl. Mech. Engrg, vol.190, pp.3039-3067, 2001. ,
An efficient preconditioner for monolithically-coupled large-displacement fluid???structure interaction problems with pseudo-solid mesh updates, Journal of Computational Physics, vol.231, issue.21, pp.7315-7334, 2012. ,
DOI : 10.1016/j.jcp.2012.07.001
An Effective Fluid-Structure Interaction Formulation for Vascular Dynamics by Generalized Robin Conditions, SIAM Journal on Scientific Computing, vol.30, issue.2, pp.731-763, 2008. ,
DOI : 10.1137/060678439
Partitioned Algorithms for Fluid-Structure Interaction Problems in Haemodynamics, Milan Journal of Mathematics, vol.4, issue.4, pp.443-467, 2012. ,
DOI : 10.1007/s00032-012-0194-7
In vivo wall shear stress measured by magnetic resonance velocity mapping in the normal human abdominal aorta, European Journal of Vascular and Endovascular Surgery, vol.13, issue.3, pp.263-271, 1997. ,
DOI : 10.1016/S1078-5884(97)80097-4
Stabilization of staggered solution procedures for fluid-structure interaction analysis, Computational Methods for Fluid-Structure Interaction Problems, pp.95-124, 1977. ,
Explicit/implicit fluid/structure staggered procedures with a structural predictor and fluid subcycling for 2D inviscid aeroelastic simulations, International Journal for Numerical Methods in Fluids, vol.134, issue.10, pp.251207-1226, 1997. ,
DOI : 10.1002/(SICI)1097-0363(19971130)25:10<1207::AID-FLD616>3.0.CO;2-R
URL : https://hal.archives-ouvertes.fr/hal-00607776
A SEMI-IMPLICIT APPROACH FOR FLUID-STRUCTURE INTERACTION BASED ON AN ALGEBRAIC FRACTIONAL STEP METHOD, Mathematical Models and Methods in Applied Sciences, vol.17, issue.06, pp.957-983, 2007. ,
DOI : 10.1142/S0218202507002170
Evolution of the wall shear stresses during the progressive enlargement of symmetric abdominal aortic aneurysms, Journal of Fluid Mechanics, vol.560, pp.19-51, 2006. ,
DOI : 10.1017/S002211200600036X
URL : https://hal.archives-ouvertes.fr/hal-01023355
Fluid-structure interaction in abdominal aortic aneurysms: effects of asymmetry and wall thickness, BioMedical Engineering OnLine, vol.4, issue.1, pp.1-22, 2005. ,
