Conference papers
Toward an Autonomous Lunar Landing Based on Low-speed Optic Flow Sensors
Abstract : For the last few decades, growing interest has returned to the quite challenging task of the autonomous lunar landing. Soft landing of payloads on the lunar surface requires the development of new means of ensuring safe descent with strong final conditions and aerospace-related constraints in terms of mass, cost and computational resources. In this paper, a two-phase approach is presented: first a biomimetic method inspired from the neuronal and sensory system of flying insects is presented as a solution to perform safe lunar landing. In order to design an autopilot relying only on optic flow (OF) and inertial measurements, an estimation method based on a two-sensor setup is introduced: these sensors allow us to accurately estimate the orientation of the velocity vector which is mandatory to control the lander's pitch in a quasi-optimal way with respect to the fuel consumption. Secondly a new low-speed Visual Motion Sensor (VMS) inspired by insects' visual systems performing local angular 1-D speed measurements ranging from 1.5°/s to 25 °/s and weighing only 2.8 g is presented. It was tested under free-flying outdoor conditions over various fields onboard an 80 kg unmanned helicopter. These preliminary results show that the optic flow measured despite the complex disturbances encountered closely matched the ground-truth optic flow.
Complete list of metadata
Cited literature [53 references]  Display  Hide  Download
https://hal.inria.fr/hal-00820225
Contributor : Guillaume Sabiron Connect in order to contact the contributor
Submitted on : Friday, May 3, 2013 - 2:27:07 PM
Last modification on : Tuesday, October 19, 2021 - 10:58:57 PM
Long-term archiving on: : Sunday, August 4, 2013 - 4:05:11 AM
File
EuroGNC_2013_Sabiron_et_al_HAL...
Identifiers
  • HAL Id : hal-00820225, version 1
Collections
Citation
Guillaume Sabiron, Paul Chavent, Laurent Burlion, Erwan Kervendal, Eric Bornschlegl, et al.. Toward an Autonomous Lunar Landing Based on Low-speed Optic Flow Sensors. EuroGNC - 2nd CEAS Specialist Conference on Guidance, Navigation & Control, Apr 2013, Delft, Netherlands. pp.993-1011. ⟨hal-00820225⟩
Share
Metrics
Record views
477
Files downloads
717
