Abstract : In this article we present a framework for modeling a building with a single Digital Elevation Model (DEM). The model is constructed in two stages. A first stage segments the DEM into planar surface patches to describe the building. Then, a polygonalisation stage generates the final polygonal model of the building by using constraints. We use robust estimation methods at different stages of our framework to develop an efficient and insensitive to noise system of modeling. The system that we propose is fully automatic and does not use any a priori information about the shape of the buildings. We present results with simple buildings and with a large area of a real city.
https://hal.inria.fr/hal-00821476
Contributeur : Frédéric Devernay
Soumis le : vendredi 10 mai 2013 - 12:51:10
Dernière modification le : lundi 27 novembre 2017 - 11:46:01
Document(s) archivé(s) le : dimanche 11 août 2013 - 04:08:05
Christophe Vestri, Frédéric Devernay, Marion Mesnage. Using robust methods to model buildings with a DEM. Accepted in ISPRS Workshop on Models and Strategies for Object Reconstruction, Bonn, Germany, Jul.. 2000. 〈hal-00821476〉
