New interface
Conference papers
Modélisation 3D+t de l'arbre coronaire à partir de séquences angiographiques
Fabien Mourgues 1 Frédéric Devernay 1 Grégoire Malandain 2 Ève Coste-Manière 1
1 CHIR - Surgery, Informatics and Robotics
CRISAM - Inria Sophia Antipolis - Méditerranée
2 EPIDAURE - Medical imaging and robotics
Abstract : We present a method for 3D+t modeling of the coronary tree from non-simultaneous angiographic sequences acquired on device monoplane angiography. Each sequence is processed by multiscale analysis model. The coronary tree is drawn in an image of each sequence with a semi-interactive tool based on preprocessing. This tree is automatically tracked in each sequence of a cardiac cycle using motion-constrained B-snakes forced to overcome the problems of crossing arteries in the image. Finally a reconstruction method from stereoscopic images synchronized with the electrocardiogram is applied to find the 3D arteries and their section. The proposed reconstruction method explicitly takes into account the problem of non-simultaneous stereo for which the epipolar constraints are not directly observed.
Document type :
Conference papers
Complete list of metadata
Cited literature [18 references]  Display  Hide  Download
https://hal.inria.fr/hal-00821478
Contributor : Frédéric Devernay Connect in order to contact the contributor
Submitted on : Friday, May 10, 2013 - 1:06:38 PM
Last modification on : Friday, February 4, 2022 - 3:24:31 AM
Long-term archiving on: : Sunday, August 11, 2013 - 4:08:13 AM
File
orasis01b.pdf
Identifiers
  • HAL Id : hal-00821478, version 1
Collections
Citation
Fabien Mourgues, Frédéric Devernay, Grégoire Malandain, Ève Coste-Manière. Modélisation 3D+t de l'arbre coronaire à partir de séquences angiographiques. Journées ORASIS - 2001, 2001, Obernai, France. ⟨hal-00821478⟩
Share
Metrics
Record views
117
Files downloads
141
