New interface
Journal articles
Correction et amélioration des résultats de la stéréoscopie par corrélation : application au MNE urbain
Abstract : Stereo by correlation can be used to produce urban DEM without a priori knowledge on the shape of buildings, as opposed to feature-based methods. Nevertheless, this method suffers from several weaknesses, e.g. at depth discontinuities located near roof borders. The classical solution is to use a correlation method with adaptive windows [Kanade et Okutomi, 1994], but we propose an alternate solution which consists in post-processing the DEM obtained by correlation. This method is based on a combination of morphomath and anisotropic diffusion techniques, and uses the local contrast of the orthoimage to determine which image areas hooked on the correlation window.
Document type :
Journal articles
Complete list of metadata
Cited literature [7 references]  Display  Hide  Download
https://hal.inria.fr/hal-00821595
Contributor : Frédéric Devernay Connect in order to contact the contributor
Submitted on : Tuesday, May 14, 2013 - 10:39:58 AM
Last modification on : Wednesday, September 22, 2021 - 8:00:03 AM
Long-term archiving on: : Thursday, August 15, 2013 - 4:11:56 AM
Identifiers
  • HAL Id : hal-00821595, version 2
Citation
Frédéric Devernay, Julien Devade. Correction et amélioration des résultats de la stéréoscopie par corrélation : application au MNE urbain. Revue Française de Photogrammétrie et de Télédétection, 1999, 153, pp.52-54. ⟨hal-00821595v2⟩
Share
Metrics
Record views
68
Files downloads
164
