How we avoid collisions with stationary and moving objects., Psychological Review, vol.102, issue.4, pp.627-651, 1995. ,
DOI : 10.1037/0033-295X.102.4.627
Visually guided collision avoidance and collision achievement, Trends in Cognitive Sciences, vol.4, issue.3, pp.99-107, 2000. ,
DOI : 10.1016/S1364-6613(99)01442-4
A Theory of Visual Control of Braking Based on Information about Time-to-Collision, Perception, vol.241, issue.2 ,
DOI : 10.1068/p050437
Optical information about the severity of upcoming contacts., Journal of Experimental Psychology: Human Perception and Performance, vol.19, issue.1 ,
DOI : 10.1037/0096-1523.19.1.179
Accuracy of estimating time to collision using binocular and monocular information, Vision Research, vol.38, issue.4, pp.499-512, 1998. ,
DOI : 10.1016/S0042-6989(97)00230-7
Weighted combination of size and disparity: A computational model for timing a ball catch, Nature Neuroscience, vol.2, pp.186-190, 1999. ,
Grasping tau, Journal of Experimental Psychology: Human Perception and Performance, vol.17, pp.315-322, 1991. ,
The negociation of stationary and moving obstructions during walking: anticipatory locomotor adaptations and preservation of personal space ,
The effects of distant and on-line visual information on the control of approach phase and step over an obstacle during locomotion, Experimental Brain Research, vol.155, issue.4, pp.459-468, 2004. ,
DOI : 10.1007/s00221-003-1751-7
Locomotor Patterns of the Leading and the Trailing Limbs as Solid and Fragile Obstacles are Stepped over: Some Insights into the Role of Vision During Locomotion, Journal of Motor Behavior, vol.8, issue.1, pp.35-47, 1996. ,
DOI : 10.1037/0033-295X.86.5.415
Influence of an unexpected perturbation on adaptive gait behavior, Gait & Posture, vol.34, issue.3, pp.439-441, 2011. ,
DOI : 10.1016/j.gaitpost.2011.06.011
Human locomotion through a multiple obstacle environment: strategy changes as a result of visual field limitation, Experimental Brain Research, vol.33, issue.3, pp.449-456, 2011. ,
DOI : 10.1007/s00221-011-2757-1
Locomotor adjustments for circumvention of an obstacle in the travel path, Experimental Brain Research, vol.152, issue.3, pp.409-414, 2003. ,
DOI : 10.1007/s00221-003-1558-6
Children use different anticipatory control strategies than adults to circumvent an obstacle in the travel path, Experimental Brain Research, vol.153, issue.3, pp.119-127, 2005. ,
DOI : 10.1007/s00221-005-0054-6
Travel path conditions dictate the manner in which individuals avoid collisions, Gait & Posture, vol.26, issue.2, pp.186-193, 2007. ,
DOI : 10.1016/j.gaitpost.2006.08.012
Locomotor avoidance behaviours during a visually guided task involving an approaching object, Gait & Posture, vol.28, issue.4, pp.596-601, 2008. ,
DOI : 10.1016/j.gaitpost.2008.04.006
Behavioral dynamics of steering, obstable avoidance, and route selection., Journal of Experimental Psychology: Human Perception and Performance, vol.29, issue.2, pp.343-362, 2003. ,
DOI : 10.1037/0096-1523.29.2.343
Behavioral dynamics of avoiding a moving obstacle, Journal of Vision, vol.3, issue.9, p.134, 2003. ,
DOI : 10.1167/3.9.134
Switching behavior in moving obstacle avoidance, Journal of Vision, vol.5, issue.8, p.312, 2005. ,
DOI : 10.1167/5.8.312
Timing and distance characteristics of interpersonal coordination during locomotion, Neuroscience Letters, vol.389, issue.1, pp.6-11, 2005. ,
DOI : 10.1016/j.neulet.2005.06.052
Exploiting Motion Capture to Enhance Avoidance Behaviour in Games, Lecture Notes in Computer Science, vol.5884, pp.29-40, 2009. ,
DOI : 10.1007/978-3-642-10347-6_3
Minimal predicted distance: A common metric for collision avoidance during pairwise interactions between walkers, Gait & Posture, vol.36, issue.3, pp.399-404, 2012. ,
DOI : 10.1016/j.gaitpost.2012.03.021
URL : https://hal.archives-ouvertes.fr/hal-00759480
Influence of Approach Angle on Estimates of Time-To-Contact, Ecological Psychology, vol.57, issue.1 ,
DOI : 10.1037/0096-1523.17.3.865
