The crust and the beta-skeleton: combinatorial curve reconstruction, Graphical Models and Image Processing, vol.60, issue.2 6, 1998. ,
Crust: A new Voronoi-based surface reconstruction algorithm, 1998. ,
Hierarchical structure recovery of point-sampled surfaces, 2010. ,
O-snap, ACM Transactions on Graphics, vol.32, issue.1, 2012. ,
DOI : 10.1145/2421636.2421642
An experimental comparison of min-cut/max-flow algorithms for energy minimization in vision, PAMI, vol.26, issue.9 5, 2004. ,
Localized delaunay refinement for piecewise-smooth complexes, Proceedings of the 29th annual symposium on Symposuim on computational geometry, SoCG '13, 2007. ,
DOI : 10.1145/2462356.2462376
Robust piecewise-planar 3D reconstruction and completion from largescale unstructured point data, CVPR, 2010. ,
Variational shape approximation, SIGGRAPH, p.8, 2004. ,
Robust moving least-squares fitting with sharp features, SIGGRAPH, 2005. ,
Surface reconstruction using local shape priors, SGP, 2007. ,
Robust reconstruction of watertight 3D models from non-uniformly sampled point clouds without normal information, In SGP, vol.1, p.5, 2006. ,
Poisson surface reconstruction, In SGP, vol.1, issue.8, 2006. ,
Direct visibility of point sets, SIGGRAPH, 2007. ,
Global optimization for shape fitting, CVPR, p.5, 2007. ,
A hybrid multi-view stereo algorithm for modeling urban scenes Creating large-scale city models from 3d-point clouds: a robust approach with hybrid representation, PAMI, vol.35, issue.3, p.7, 2012. ,
Robust and efficient surface reconstruction from range data, p.5, 2009. ,
Globfit: Consistently fitting primitives by discovering global relations, SIGGRAPH, 2011. ,
Symmetry in 3d geometry: Extraction and applications, 2012. ,
A survey of urban reconstruction, EUROGRAPHICS STARs, 2012. ,
Completion and reconstruction with primitive shapes, Eurographics, 2009. ,
Efficient RANSAC for point-cloud shape detection, p.7, 2007. ,
Feature preserving mesh generation from 3D point clouds, SGP, 2010. ,
Automatic extraction of manhattan-world building masses from 3d laser range scans, p.10, 2012. ,
Non-local scan consolidation for 3D urban scenes, SIGGRAPH, 2010. ,
