Traceability between models and texts through terminology
Modeling often concerns the translation of informal texts into representations. This translation process requires support for itself and for its traceability. We pretend that inserting a terminology between informal textual documents and their formalization can help to serve both of these goals. Modern terminology extraction tools support the formalization process by using terms as a first sketch of formalized concepts. Moreover, the terms can be employed for linking the concepts and the textual sources. They act as a powerful navigation structure. This is exemplified through the presentation of a fully implemented system.
