Ontology Language Integration: A Constructive Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2001
The problem of integrating different ontology languages has become of special interest recently, especially in the context of semantic web applications. In the paper, we present an approach that is based on the configuration of a joint language all other languages can be translated into. We use description logics as a basis for constructing this common language taking advantage of the modular character and the availability of profound theoretical results in this area. We give the central definitions and exemplify the approach using example ontologies available on the Web.
stuckenschmidt2001a.pdf (117.27 Ko) Télécharger le fichier
hal-00822916 , version 1 (15-05-2013)
  • HAL Id : hal-00822916 , version 1
Heiner Stuckenschmidt, Jérôme Euzenat. Ontology Language Integration: A Constructive Approach. Proc. KI 2001 workshop on Applications of Description Logics, Sep 2001, Wien, Austria. No pagination. ⟨hal-00822916⟩
140 Consultations
79 Téléchargements
