A Research Survey on Large XML Data: Streaming, Selectivity Estimation and Parallelism - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2013
Semi-structured data sets in the form of XML documents have many practical uses and they have motivated a very large amount of work in theoretical, applied and industrial computing. Their efficient exploitation requires specific methods for filtering and querying them, using techniques that are neither keyword searches nor relational methods. In this paper we survey a large body of recent research on efficient querying methods for XML data. Our analysis of the literature follows the three dimensions of stream-processing, parallel processing and performance variability.
Fichier non déposé
hal-00823325 , version 1 (16-05-2013)
  • HAL Id : hal-00823325 , version 1
Muath Alrammal, Gaétan Hains. A Research Survey on Large XML Data: Streaming, Selectivity Estimation and Parallelism. F. Xhafa and N. Bessis. Inter-cooperative Collective Intelligence: Techniques and Applications, Springer, 2013, ISBN 978-3-642-35015-3. ⟨hal-00823325⟩
136 Consultations
0 Téléchargements
