Conference papers
A Fault-Tolerant Approach to Distributed Applications
Toan Nguyen 1 Jean-Antoine Desideri 1 Laurentiu Trifan 1
1 OPALE - Optimization and control, numerical algorithms and integration of complex multidiscipline systems governed by PDE
CRISAM - Inria Sophia Antipolis - Méditerranée , JAD - Laboratoire Jean Alexandre Dieudonné : UMR6621
Abstract : Distributed computing infrastructures support system and network fault-tolerance, e.g., grids and clouds. They transparently repair and prevent communication and system software errors. They also allow duplication and migration of jobs and data to prevent hardware failures. However, only limited work has been done so far on application resilience, i.e., the ability to resume normal execution after errors and abnormal executions in distributed environments. This paper addresses issues in application resilience, i.e., fault-tolerance to algorithmic errors and to resource allocation failures. It addresses solutions for error detection and management. It also overviews a platform used to deploy, execute, monitor, restart and resume distributed applications on grids and cloud infrastructures in case of unexpected behavior.
Complete list of metadata
Cited literature [29 references]  Display  Hide  Download
https://hal.inria.fr/hal-00823329
Contributor : Toan Nguyen Connect in order to contact the contributor
Submitted on : Thursday, June 13, 2013 - 2:21:25 PM
Last modification on : Friday, August 5, 2022 - 3:50:27 AM
Long-term archiving on: : Saturday, September 14, 2013 - 4:13:49 AM
File
PDPTA2013.pdf
Identifiers
  • HAL Id : hal-00823329, version 3
Citation
Toan Nguyen, Jean-Antoine Desideri, Laurentiu Trifan. A Fault-Tolerant Approach to Distributed Applications. Parallel and Distributed Processing Techniques and Applications (PDPTA'13), Jul 2013, Las Vegas, United States. ⟨hal-00823329v3⟩
Share
Metrics
Record views
209
Files downloads
268
