Computing Hilbert Class Polynomials, Algorithmic Number Theory, 8th International Symposium, ANTS-VIII Proceedings, pp.282-295, 2008. ,
DOI : 10.1007/978-3-540-79456-1_19
URL : https://hal.archives-ouvertes.fr/inria-00246115
Das arithmetisch-geometrische Mittel aus vier Elementen, Monatsberichte der Königlich Preußischen Akademie der Wissenschaften zu Berlin, pp.611-621, 1876. ,
DOI : 10.1515/crll.1861.58.127
URL : http://www.digizeitschriften.de/download/PPN243919689_0058/PPN243919689_0058___log10.pdf
Theorie des arithmetisch-geometrischen Mittels aus vier Elementen, Mathematische Abhandlungen der Königlichen Akademie der Wissenschaften zu Berlin, pp.33-96, 1878. ,
Pi and the AGM, 1987. ,
Modern Computer Arithmetic, Cambridge Monographs on Applied and Computational Mathematics, vol.18, 2010. ,
DOI : 10.1017/CBO9780511921698
URL : https://hal.archives-ouvertes.fr/cel-01500109
Fast Multiple-Precision Evaluation of Elementary Functions, Journal of the ACM, vol.23, issue.2, pp.242-251, 1976. ,
DOI : 10.1145/321941.321944
A $p$-adic algorithm to compute the Hilbert class polynomial, Mathematics of Computation, vol.77, issue.264, pp.2417-2435, 2008. ,
DOI : 10.1090/S0025-5718-08-02091-7
Explicit CM theory for level 2-structures on abelian surfaces, Algebra & Number Theory, vol.5, issue.4, pp.495-528, 2011. ,
DOI : 10.2140/ant.2011.5.495
A course in algorithmic algebraic number theory, volume 138 of Grad. Texts in Math, 1993. ,
Applications des fonctions thêta à la cryptographie sur courbes hyperelliptiques. Thèse, Université Henri Poincaré -Nancy I, 2011. ,
Action of Modular Correspondences around CM Points, Algorithmic Number Theory ? ANTS-V, volume 2369 of Lecture Notes in Computer Science, pp.234-243, 2002. ,
DOI : 10.1007/3-540-45455-1_19
Fast evaluation of modular functions using Newton iterations and the AGM, Mathematics of Computation, vol.80, issue.275, pp.1823-1847, 2011. ,
DOI : 10.1090/S0025-5718-2011-01880-6
URL : https://hal.archives-ouvertes.fr/hal-00644845
Moyenne arithmético-géométrique, suites de Bor- chardt et applications, Thèse, École Polytechnique, 2006. ,
The complexity of class polynomial computation via floating point approximations, Mathematics of Computation, vol.78, issue.266, pp.1089-1107, 2009. ,
DOI : 10.1090/S0025-5718-08-02200-X
URL : https://hal.archives-ouvertes.fr/inria-00001040
Mpfrcx ? A library for univariate polynomials over arbitrary precision real or complex numbers. INRIA, 2013. ,
Gnu Mpc ? A library for multiprecision complex arithmetic with exact rounding. INRIA, 2012. ,
Fast Decomposition of Polynomials with Known Galois Group, Lecture Notes in Computer Science, vol.2643, pp.254-264, 2003. ,
DOI : 10.1007/3-540-44828-4_27
Cmh ? Computation of Igusa Class Polynomials, Development version, 2013. ,
The 2-Adic CM Method for Genus 2 Curves with Application to Cryptography, Advances in Cryptology ? ASIACRYPT 2006, pp.114-129, 2006. ,
DOI : 10.1007/11935230_8
URL : https://hal.archives-ouvertes.fr/inria-00103435
Explizite Bestimmung der Randfl???chen des Fundamentalbereiches der Modulgruppe zweiten Grades, Mathematische Annalen, vol.83, issue.2, pp.103-124, 1959. ,
DOI : 10.1007/BF01342938
Gmp ? The Gnu Multiple Precision Arithmetic Library, 2013. ,
Gnu Mpfr ? A library for multiple-precision floating-point computations with exact rounding, 2013. ,
On Siegel Modular Forms of Genus Two, American Journal of Mathematics, vol.84, issue.1, pp.175-200, 1962. ,
DOI : 10.2307/2372812
Theta functions, volume 194 of Die Grundlehren der mathematischen Wissenschaften, 1972. ,
Introductory lectures on Siegel modular forms, volume 20 of Cambridge studies in advanced mathematics, 1990. ,
Improved CRT algorithm for class polynomials in genus 2 of The Open Book Series, ANTS X ? Proceedings of the Tenth Algorithmic Number Theory Symposium, pp.437-461, 2013. ,
Construction de courbes de genre 2 ?? partir de leurs modules, Effective methods in algebraic geometry, pp.313-334, 1991. ,
DOI : 10.1007/978-1-4612-0441-1_21
Abelian Varieties with Complex Multiplication and Modular Functions, 1998. ,
DOI : 10.1515/9781400883943
Complex Multiplication of Abelian Varieties and its Applications to Number Theory, 1961. ,
Kurven vom Geschlecht 2 und ihre Anwendung in Public- Key-Kryptosystemen, 1994. ,
Computing Igusa class polynomials, Mathematics of Computation, vol.83, issue.285, p.4766, 2009. ,
DOI : 10.1090/S0025-5718-2013-02712-3
URL : http://arxiv.org/abs/0903.4766
Complex multiplication of abelian surfaces, 2010. ,
Modern Computer Algebra, 1999. ,
