Robustness of Nonlinear Systems with Respect to Delay and Sampling of the Controls - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Automatica Année : 2013
We consider continuous time nonlinear time varying systems that are globally asymptotically stabilizable by state feedbacks. We study the stability of these systems in closed loop with controls that are corrupted by both delay and sampling. We establish robustness results through a Lyapunov approach of a new type.
Robustesse de systèmes non linéaires avec retard et échantillonnage.
Automatique
21Oct2012FMSamplingDraft.pdf (337.55 Ko) Télécharger le fichier
hal-00823918 , version 1 (19-05-2013)
Frédéric Mazenc, Michael Malisoff, Thach Ngoc Dinh. Robustness of Nonlinear Systems with Respect to Delay and Sampling of the Controls. Automatica, 2013, 49 (6), pp.1925-1931. ⟨10.1016/j.automatica.2013.02.064⟩. ⟨hal-00823918⟩
348 Consultations
329 Téléchargements
