DTW-Radon-based Shape Descriptor for Pattern Recognition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Pattern Recognition and Artificial Intelligence Année : 2013
In this paper, we present a pattern recognition method that uses dynamic programming (DP) for the alignment of Radon features. The key characteristic of the method is to use dynamic time warping (DTW) to match corresponding pairs of the Radon features for all possible projections. Thanks to DTW, we avoid compressing the feature matrix into a single vector which would otherwise miss information. To reduce the possible number of matchings, we rely on a initial normalisation based on the pattern orientation. A comprehensive study is made using major state-of-the-art shape descriptors over several public datasets of shapes such as graphical symbols (both printed and hand-drawn), handwritten characters and footwear prints. In all tests, the method proves its generic behaviour by providing better recognition performance. Overall, we validate that our method is robust to deformed shape due to distortion, degradation and occlusion.
kc_IJPRAI0.pdf (2.65 Mo) Télécharger le fichier
hal-00823961 , version 1 (20-05-2013)
Santosh K.C., Bart Lamiroy, Laurent Wendling. DTW-Radon-based Shape Descriptor for Pattern Recognition. International Journal of Pattern Recognition and Artificial Intelligence, 2013, 27 (3), ⟨10.1142/S0218001413500080⟩. ⟨hal-00823961⟩
225 Consultations
458 Téléchargements
