Learning Sparse Penalties for Change-Point Detection using Max Margin Interval Regression - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In segmentation models, the number of change-points is typically chosen using a pe- nalized cost function. In this work, we pro- pose to learn the penalty and its constants in databases of signals with weak change-point annotations. We propose a convex relaxation for the resulting interval regression problem, and solve it using accelerated proximal gra- dient methods. We show that this method achieves state-of-the-art change-point detec- tion in a database of annotated DNA copy number profiles from neuroblastoma tumors.
Fichier non déposé
hal-00824075 , version 1 (21-05-2013)
  • HAL Id : hal-00824075 , version 1
Guillem Rigaill, Toby Dylan Hocking, Francis Bach, Jean-Philippe Vert. Learning Sparse Penalties for Change-Point Detection using Max Margin Interval Regression. ICML 2013 - 30 th International Conference on Machine Learning, Supported by the International Machine Learning Society (IMLS), Jun 2013, Atlanta, United States. ⟨hal-00824075⟩
404 Consultations
0 Téléchargements
