The complexity of deciding whether a graph admits an orientation with fixed weak diameter - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2014
Sergey Kirgizov
An orientation of an undirected graph G has weak diameter k if, for every pair {u,v} of vertices of G, there is a directed path with length at most k joining u and v in either direction. We show that deciding whether a graph admits an orientation with weak diameter k is NP-complete whenever k>=2.
weak-diam.pdf (301.31 Ko) Télécharger le fichier
hal-00824250 , version 1 (21-05-2013)
hal-00824250 , version 2 (22-05-2013)
hal-00824250 , version 3 (05-06-2013)
hal-00824250 , version 4 (20-11-2013)
hal-00824250 , version 5 (18-09-2014)
hal-00824250 , version 6 (16-08-2016)
  • HAL Id : hal-00824250 , version 5
Julien Bensmail, Romaric Duvignau, Sergey Kirgizov. The complexity of deciding whether a graph admits an orientation with fixed weak diameter. 2014. ⟨hal-00824250v5⟩
Collections
UPMC LIP6
750 Consultations
1218 Téléchargements
