Numerical Methods for Nonsmooth Dynamical Systems, Lecture Notes in Applied and Computational Mechanics, vol.35, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00423530
Regularization of constraint singularities in multibody systems, Multibody System Dynamics, vol.6, issue.4, pp.355-375, 2001. ,
DOI : 10.1023/A:1012084517966
The Dynamics of Discrete Mechanical Systems with Perfect Unilateral Constraints, Archive for Rational Mechanics and Analysis, vol.154, issue.3, pp.199-274, 2000. ,
DOI : 10.1007/s002050000105
URL : https://hal.archives-ouvertes.fr/hal-00111308
Matrix, Mathematics. Theory, Facts, and Formulas with Application to Linear Systems Theory, 2005. ,
Augmented Lagrangian formulation: geometrical interpretation and application to systems with singularities and redundancy, Multibody System Dynamics, vol.8, issue.2, pp.141-159, 2002. ,
DOI : 10.1023/A:1019581227898
Nonsmooth Mechanics, 1999. ,
DOI : 10.1007/978-1-4471-0557-2
URL : https://hal.archives-ouvertes.fr/hal-01236953
On a Problem in Linear Inequalities, Journal of the London Mathematical Society, vol.1, issue.1, pp.378-384, 1968. ,
DOI : 10.1112/jlms/s1-43.1.378
The Linear Complementarity Problem, Computer Science and Scientific Computing, 1992. ,
M??moire sur la th??orie des liaisons finies unilat??rales, Annales scientifiques de l'??cole normale sup??rieure, vol.34, pp.34-95, 1917. ,
DOI : 10.24033/asens.701
A sweeping process approach to inelastic contact problems with general inertia operators, European Journal of Mechanics - A/Solids, vol.26, issue.3, pp.474-490, 2007. ,
DOI : 10.1016/j.euromechsol.2006.07.002
A convergence result for a vibro-impact problem with??a??general inertia operator, Nonlinear Dynamics, vol.2, issue.2, pp.1-2, 2009. ,
DOI : 10.1007/978-3-0348-7614-8
URL : https://hal.archives-ouvertes.fr/hal-01552482
Finite-Dimensional Variational Inequalities and Complementarity Problems, Series in Operations Research, 2003. ,
Non-smooth Thermomechanics, 2002. ,
New results on Painlev?? paradoxes, European Journal of Mechanics - A/Solids, vol.18, issue.4, pp.653-677, 1999. ,
DOI : 10.1016/S0997-7538(99)00144-8
Set-Valued Force Laws: Dynamics of Non-smooth Systems, Lecture Notes in Applied and Computational Mechanics, vol.1, 2001. ,
DOI : 10.1007/978-3-540-44479-4
Concepts for modeling impacts without friction, Acta Mechanica, vol.168, issue.1-2, pp.1-19, 2004. ,
DOI : 10.1007/s00707-004-0076-3
URL : http://www.zfm.ethz.ch/~glocker/publicationpdf/journal publications/bw_2004_actamechanica.pdf
An Introduction to Impacts, Nonsmooth Mechanics of Solids. CISM Courses and Lectures, pp.45-102, 2006. ,
DOI : 10.1007/978-3-211-48243-8_2
The Geometry Of Newton???s Cradle, Nonsmooth Mechanics and Analysis. Theoretical and Numerical Advances. AMMA, pp.185-194, 2006. ,
DOI : 10.1007/0-387-29195-4_16
Fundamentals of Convex Analysis. Grundlehren Text Editions, 2001. ,
DOI : 10.1007/978-3-642-56468-0
The Theory of Matrices, 1985. ,
Dynamics and Bifurcations of Non-smooth Mechanical Systems, Lecture Notes in Applied and Computational Mechanics, vol.18, 2004. ,
DOI : 10.1007/978-3-540-44398-8
Stability and Convergence of Mechanical Systems with Unilateral Constraints, Lecture Notes in Applied and Computational Mechanics, vol.36, 2008. ,
DOI : 10.1007/978-3-540-76975-0
Stability properties of equilibrium sets of non-linear mechanical systems with dry friction and impact, Nonlinear Dynamics, vol.43, issue.4, pp.551-583, 2008. ,
DOI : 10.1142/5442
Mechanical Systems of Rigid Bodies Subject to Unilateral Constraints, SIAM Journal on Applied Mathematics, vol.42, issue.2, pp.281-296, 1982. ,
DOI : 10.1137/0142022
A unified variational model for the dynamics of perfect unilateral constraints, European Journal of Mechanics - A/Solids, vol.17, issue.5, pp.819-842, 1998. ,
DOI : 10.1016/S0997-7538(98)80007-7
Feedback stabilization and tracking of constrained robots, IEEE Transactions on Automatic Control, vol.33, issue.5, pp.419-426, 1988. ,
DOI : 10.1109/9.1220
Differential Inclusions in Non-smooth Mechanical Problems: Shocks and Dry Friction, Birkhäuser, 1993. ,
Les liaisons unilatérales et le principe de Gauss, C. R. Acad. Sci. Paris, vol.256, issue.4, pp.871-874, 1963. ,
Quadratic Programming in Mechanics: Dynamics of One-Sided Constraints, SIAM Journal on Control, vol.4, issue.1, pp.153-158, 1966. ,
DOI : 10.1137/0304014
URL : https://hal.archives-ouvertes.fr/hal-01379713
Unilateral Contact and Dry Friction in Finite Freedom Dynamics, Nonsmooth Mechanics and Applications. CISM Courses and Lectures, pp.1-82, 1988. ,
DOI : 10.1007/978-3-7091-2624-0_1
A Lie-group formulation of kinematics and dynamics of constrained MBS and its application to analytical mechanics, Multibody System Dynamics, vol.9, issue.4, pp.311-352, 2003. ,
DOI : 10.1023/A:1023321630764
A conservative elimination procedure for permanently redundant closure constraints in MBS-models with relative coordinates, Multibody System Dynamics, vol.14, issue.1, pp.309-330, 2006. ,
DOI : 10.1007/978-1-4757-2484-4
Stabilization methods for the integration of DAE in the presence of redundant constraints, Multibody System Dynamics, vol.10, issue.1, pp.81-105, 2003. ,
DOI : 10.1023/A:1024567523268
Investigation of Painlev?????s paradox and dynamic jamming during mechanism sliding motion, Nonlinear Dynamics, vol.75, issue.2, pp.1647-1668, 2012. ,
DOI : 10.1002/rnc.592
CONTINUOUS DEPENDENCE ON DATA FOR VIBRO-IMPACT PROBLEMS, Mathematical Models and Methods in Applied Sciences, vol.359, issue.01, pp.1-41, 2005. ,
DOI : 10.1098/rsta.2001.0859
Time-Stepping Approximation of Rigid-Body Dynamics with Perfect Unilateral Constraints. I: The Inelastic Impact Case, Archive for Rational Mechanics and Analysis, vol.359, issue.3, pp.457-568, 2010. ,
DOI : 10.1016/S0764-4442(00)88482-7
URL : https://hal.archives-ouvertes.fr/hal-01566929
A proximal-like method for a class of second order measure-differential inclusions describing vibro-impact problems, Journal of Differential Equations, vol.250, issue.1, pp.476-514, 2011. ,
DOI : 10.1016/j.jde.2010.10.010
URL : https://hal.archives-ouvertes.fr/hal-01566931
Mouvement ?? un nombre fini de degr??s de libert?? avec contraintes unilat??rales : cas avec perte d'??nergie, ESAIM: Mathematical Modelling and Numerical Analysis, vol.27, issue.6, pp.673-717, 1993. ,
DOI : 10.1051/m2an/1993270606731
URL : http://www.esaim-m2an.org/articles/m2an/pdf/1993/06/m2an1993270606731.pdf
Multibody Dynamics with Unilateral Contacts, 1996. ,
DOI : 10.1002/9783527618385
Convex Analysis, Princeton Landmarks in Mathematics, 1970. ,
DOI : 10.1515/9781400873173
A class of nonlinear differential equations of second order in time, Nonlinear Analysis: Theory, Methods & Applications, vol.2, issue.3, pp.355-373, 1978. ,
DOI : 10.1016/0362-546X(78)90022-6
URL : https://hal.archives-ouvertes.fr/hal-01294058
Impact Mechanics, 2000. ,
DOI : 10.1017/CBO9780511626432
Numerics of Unilateral Contacts and Friction: Modeling and Numerical Time Integration in Non-smooth Dynamics, Lecture Notes in Applied and Computational Mechanics, vol.47, 2009. ,
DOI : 10.1007/978-3-642-01100-9
