G. Ch and F. Pfeiffer, Multiple impacts with friction in rigid multibody systems, Nonlinear Dyn, vol.7, pp.471-497, 1995.
A. Ivanov, On multiple impact, Journal of Applied Mathematics and Mechanics, vol.59, issue.6, pp.887-902, 1995.
DOI : 10.1016/0021-8928(95)00122-0
J. Moreau, Unilaterial contact and dry friction in finite freedom dynamics, CISM nonsmooth mechanics and applications, pp.1-82, 1988.
DOI : 10.1007/978-3-7091-2624-0_1
H. Lankarani and P. Nikravesh, Continuous contact force models for impact analysis in multibody systems, Nonlinear Dyn, vol.5, pp.193-207, 1994.
W. Stronge, Impact mechanics, 2000.
DOI : 10.1017/CBO9780511626432
J. Escalona, J. Sany, and A. Shabana, On the use of the restitution condition in flexible body dynamics. Nonlinear Dyn, pp.71-86, 2002.
W. Schiehlen, Multibody system dynamics: roots and perspectives, Multibody System Dynamics, vol.1, issue.2, pp.149-188, 1997.
DOI : 10.1023/A:1009745432698
D. Stewart, Rigid-Body Dynamics with Friction and Impact, SIAM Review, vol.42, issue.1, pp.3-39, 2000.
DOI : 10.1137/S0036144599360110
URL : https://hal.archives-ouvertes.fr/hal-01570533
A. Ivanov, Singularities in the dynamics of systems with non-ideal constraints, Journal of Applied Mathematics and Mechanics, vol.67, issue.2, pp.185-192, 2003.
DOI : 10.1016/S0021-8928(03)90004-9
F. Génot and B. Brogliato, New results on Painlev?? paradoxes, European Journal of Mechanics - A/Solids, vol.18, issue.4, pp.653-677, 1999.
DOI : 10.1016/S0997-7538(99)00144-8
C. Liu, Z. Zhao, and C. B. , The bouncing motion appearing in a robotic system with unilateral constraint. Nonlinear Dyn, pp.217-232, 2007.
P. Painlevé, 1895 Sur les lois du frottement de glissement, C.R. Hebd. Séances Acad. Sci. Paris, vol.121, pp.112-115
Z. Zhao, C. Liu, W. Ma, and C. B. , Experimental Investigation of the Painleve?? Paradox in a Robotic System, Journal of Applied Mechanics, vol.75, issue.4, p.41006, 2008.
DOI : 10.1115/1.2910825
P. Garland and R. Rogers, An experiment study of contact forces during oblique elastic impact, J. Appl. Mech, 2009.
DOI : 10.1115/1.3063634
M. Maw, J. Barber, and J. Fawcett, The rebound of elastic bodies in oblique impact, Mechanics Research Communications, vol.4, issue.1, pp.17-22, 1977.
DOI : 10.1016/0093-6413(77)90045-3
E. Falcon, C. Laroche, S. Fauve, and S. Coste, Collision of a 1-D column of beads with a wall, The European Physical Journal B, vol.5, issue.1, pp.111-131, 1998.
DOI : 10.1007/s100510050424
Y. Khulief and A. Shabana, 1987 A continuous force model for the impact analysis of flexible multibody systems, Mech. Mach. Theory, vol.2287, pp.213-224
C. Liu, Z. Zhao, and B. Brogliato, Frictionless multiple impacts in multibody systems. I. Theoretical framework, Proc. R. Soc. A, pp.3193-3211, 2008.
DOI : 10.1016/0022-460X(90)90665-M
URL : https://hal.archives-ouvertes.fr/inria-00204018
C. Liu, Z. Zhao, and B. Brogliato, Energy dissipation and dispersion effects in a granular media, Phys. Rev, 2008.
N. Nguyen and B. Brogliato, Shock dynamics in granular chains: numerical simulations and comparison with experimental tests, Granular Matter, vol.465, issue.2107, pp.341-362
DOI : 10.1098/rspa.2008.0520
URL : https://hal.archives-ouvertes.fr/inria-00597468
Z. Zhao, C. Liu, and B. Brogliato, Planar dynamics of a rigid body system with frictional impacts. II. Qualitative analysis and numerical simulations, Proc. R. Soc. A 465, pp.2267-2292, 2009.
URL : https://hal.archives-ouvertes.fr/hal-00755926
G. Darboux, 1880 Etude géométrique sur les percussions et le choc des corps, Bulletin des Sciences Mathématiques et Astronomiques Deuxième Série, vol.4, pp.126-160
DOI : 10.20537/nd1002013
J. Keller, Impact With Friction, Journal of Applied Mechanics, vol.53, issue.1, pp.1-4, 1986.
DOI : 10.1115/1.3171712
V. Bhatt, Three-Dimensional Frictional Rigid-Body Impact, Journal of Applied Mechanics, vol.62, issue.4, pp.893-898, 1995.
DOI : 10.1115/1.2896017
A. Nordmark, H. Dankowicz, and A. Champneys, Discontinuity-induced bifurcations in systems with impacts and friction: Discontinuities in the impact law, International Journal of Non-Linear Mechanics, vol.44, issue.10, 2009.
DOI : 10.1016/j.ijnonlinmec.2009.05.009
URL : https://hal.archives-ouvertes.fr/hal-00586125
B. Oded, S. Rubinstein, and F. Jay, 2010 Slip?stick and the evolution of frictional strength, Nature, vol.463, pp.76-79
H. Dankowicz, On the Modeling of Dynamic Friction Phenomena, 6<399::AID-ZAMM399>3.0.CO, pp.399-4091521, 1999.
DOI : 10.1002/(SICI)1521-4001(199906)79:6<399::AID-ZAMM399>3.0.CO;2-K
M. Eriten, A. Polycarpou, and L. Bergman, Physics-based modeling for fretting behavior of nominally flat rough surfaces, International Journal of Solids and Structures, vol.48, issue.10, pp.1436-1450
DOI : 10.1016/j.ijsolstr.2011.01.028
M. Eriten, A. Polycarpou, and L. Bergman, A Physics-Based Friction Model and Integration to a Simple Dynamical System, Journal of Vibration and Acoustics, vol.134, issue.5, pp.51012-51022
DOI : 10.1115/1.4006182
Y. Jia, Three-dimensional impact: energy-based modeling of tangential compliance, The International Journal of Robotics Research, vol.2, issue.3, pp.56-83, 2013.
DOI : 10.1002/rob.4620020307
Y. Jia, T. Matthew, and A. Michael, Multiple impacts: A state transition diagram approach, The International Journal of Robotics Research, vol.2, issue.031307, pp.84-114
URL : http://www.cs.iastate.edu/~jia/papers/IJRR13b.pdf
