Applying an analytic method for matching approach selection
One of the main open issues in the ontology matching field is the selection of a current relevant and suitable matcher. The suitability of the given approaches is determined w.r.t the requirements of the application and with careful consideration of a number of factors. This work proposes a multilevel characteristic for matching approaches, which provides a basis for the comparison of different matchers and is used in the decision making process for selection the most appropriate algorithm.
