Ten challenges for ontology matching - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
This paper aims at analyzing the key trends and challenges of the ontology matching field. The main motivation behind this work is the fact that despite many component matching solutions that have been developed so far, there is no integrated solution that is a clear success, which is robust enough to be the basis for future development, and which is usable by non expert users. In this paper we first provide the basics of ontology matching with the help of examples. Then, we present general trends of the field and discuss ten challenges for ontology matching, thereby aiming to direct research into the critical path and to facilitate progress of the field.
Autre [cs.OH]
shvaiko2008a.pdf (571.16 Ko) Télécharger le fichier
hal-00825956 , version 1 (24-05-2013)
Pavel Shvaiko, Jérôme Euzenat. Ten challenges for ontology matching. Proc. 7th international conference on ontologies, dataBases, and applications of semantics (ODBASE), Nov 2008, Monterey, Mexico. pp.1163-1181, ⟨10.1007/978-3-540-88873-4_18⟩. ⟨hal-00825956⟩
162 Consultations
1579 Téléchargements
