Abstract : In reinforcement learning, it is a common practice to map the state(-action) space to a different one using ba- sis functions. This transformation aims to represent the input data in a more informative form that facilitates and improves subsequent steps. As a "good" set of basis func- tions result in better solutions and defining such functions becomes a challenge with increasing problem complexity, it is beneficial to be able to generate them automatically. In this paper, we propose a new approach based on Bellman residual for constructing basis functions using cascade- correlation learning architecture. We show how this ap- proach can be applied to Least Squares Policy Iteration al- gorithm in order to obtain a better approximation of the value function, and consequently improve the performance of the resulting policies. We also present the effectiveness of the method empirically on some benchmark problems.
