A Column Generation Algorithm for a Rich Vehicle-Routing Problem, Transportation Science, vol.43, issue.1, 2009. ,
DOI : 10.1287/trsc.1080.0256
A collaborative combination between column generation and ant colony optimization for solving set packing problems, 9th Metaheuristics International Conference, 2011. ,
Vehicle routing with a sparse feasibility graph, European Journal of Operational Research, vol.98, issue.3, 1997. ,
DOI : 10.1016/S0377-2217(96)00048-3
A hybrid algorithm for the capacitated vehicle routing problem with three-dimensional loading constraints, Computers & Operations Research, vol.39, issue.9, 2010. ,
DOI : 10.1016/j.cor.2011.11.008
Scheduling of vehicles from a central depot to a number of delivery points, Oper. Res, vol.12, 1964. ,
Metaheuristics for the vehicle routing problem with loading constraints, Networks, vol.86, issue.4, p.49, 2007. ,
DOI : 10.1002/net.20179
Pheromone-Based Heuristic Column Generation for Vehicle Routing Problems with Black Box Feasibility, CPAIOR'12, 2012. ,
DOI : 10.1007/978-3-642-29828-8_17
Metaheuristics for vehicle routing problems with three-dimensional loading constraints, European Journal of Operational Research, vol.201, issue.3, 2010. ,
DOI : 10.1016/j.ejor.2009.03.046
A Tabu Search Algorithm for a Routing and Container Loading Problem, Transportation Science, vol.40, issue.3, 2006. ,
DOI : 10.1287/trsc.1050.0145
Efficient global optimization of expensive black-box functions, J. Global Opt, vol.13, 1998. ,
The challenge of optimizing expensive black boxes: a scatter search/rough set theory approach, Journal of the Operational Research Society, vol.18, issue.1, p.61, 2010. ,
DOI : 10.1007/11903697_33
European Driver Rules in Vehicle Routing with Time Windows, Transportation Science, vol.44, issue.4, 2010. ,
DOI : 10.1287/trsc.1100.0328
A savings based ant system for the vehicle routing problem, Proceedings of the Genetic and Evolutionary Computation Conference, 2002. ,
On Index Structures in Hybrid Metaheuristics for Routing Problems with Hard Feasibility Checks: An Application to the 2-Dimensional Loading Vehicle Routing Problem, Hybrid Metaheuristics, 2010. ,
DOI : 10.1007/978-3-642-16054-7_12
A hybrid metaheuristic algorithm for the integrated vehicle routing and three-dimensional containerloading problem, IEEE Trans. Intell. Transp. Syst, vol.10, 2009. ,
Heuristic and exact algorithms for the multi-pile vehicle routing problem, OR Spectrum, vol.195, issue.1, 2009. ,
DOI : 10.1007/s00291-009-0179-2
