Numerical approximation of parabolic problems by residual distribution schemes, International Journal for Numerical Methods in Fluids, vol.49, issue.11, pp.1191-1206, 2013. ,
DOI : 10.1002/fld.3710
URL : https://hal.archives-ouvertes.fr/hal-00647999
Construction of a high order Residual Distribution scheme for complex viscous flows, Seventh International Conference on Computational Fluid Dynamics (ICCFD7), 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00716621
An Example of High Order Residual Distribution Scheme Using non-Lagrange Elements, Journal of Scientific Computing, vol.59, issue.7, pp.3-25, 2010. ,
DOI : 10.1007/s10915-010-9405-y
URL : https://hal.archives-ouvertes.fr/inria-00403691
Hierarchical finite element bases for triangular and tetrahedral elements, Computer Methods in Applied Mechanics and Engineering, vol.190, issue.22-23, pp.2925-2941, 2001. ,
DOI : 10.1016/S0045-7825(00)00273-5
Hybrid scheduling for the parallel solution of linear systems, Parallel Computing, vol.32, issue.2, pp.136-156, 2006. ,
DOI : 10.1016/j.parco.2005.07.004
URL : https://hal.archives-ouvertes.fr/hal-00358623
A fully asynchronous multifrontal solver using distributed dynamic scheduling, SIAM J. Matrix Anal. Appl, vol.23, issue.1, pp.15-41, 2001. ,
Finite volume solution of boussinesq-type euations on an unstructured grid, Proc. of the 30 th Int. Conf. on Coastal Engineering, 2006. ,
Numerical Methods for Gasdynamic Systems on Unstructured Meshes, Lecture Notes in Computational Science and Engineering, vol.5, pp.195-285, 1998. ,
DOI : 10.1007/978-3-642-58535-7_5
A formal derivation and numerical modeling of the improved boussinesq equations for varying depth, Ocean Engineering, vol.23, 1996. ,
Adaptive Mesh Refinement Using Wave-Propagation Algorithms for Hyperbolic Systems, SIAM Journal on Numerical Analysis, vol.35, issue.6, 1998. ,
DOI : 10.1137/S0036142997315974
Verification of numerical wave propagation models for simple harmonic linear water waves, Coastal Engineering, vol.6, issue.3, pp.255-279, 1982. ,
DOI : 10.1016/0378-3839(82)90022-9
Modeling of periodic wave transformation in the inner surf zone, Ocean Engineering, vol.34, 2007. ,
A splitting approach for the fully nonlinear and wakly dispersive green-naghdi model, Journal of Computational Physics, vol.230, 2011. ,
Unsteady free surface flow simulation over complex topography with a multidimensional upwind technique, Journal of Computational Physics, vol.186, issue.2, pp.503-526, 2003. ,
DOI : 10.1016/S0021-9991(03)00072-X
A fourth order compact finite volume scheme for fully nonlinear and weakly dispersive boussinesq type equations. parti II: Boundary conditions and validation, Int. J. Numer. Meth. Fluids, vol.53, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-00182841
A taylor-galerkin method for simulating nonlinear dispersive water waves, Journal of computational physics, vol.146, pp.546-569, 1998. ,
Residual Distribution Schemes: Foundations and Analysis, Encyclopedia of Computational Mechanics, 2007. ,
DOI : 10.1002/0470091355.ecm054
URL : https://hal.archives-ouvertes.fr/hal-00402592
Introduction to residual distribution schemes and stabilized finite elements, VKI LS 2003-05, 33 rd Computational Fluid dynamics Course, von Karman Institute for Fluid Dynamics, 2003. ,
Finite volume schemes for dispersive wave propagation and runup, Journal of Computational Physics, vol.230, issue.8, 2011. ,
DOI : 10.1016/j.jcp.2011.01.003
URL : https://hal.archives-ouvertes.fr/hal-00472431
Unstructured nodal dg-fem solution of high order boussinesq type equations, 2006. ,
DG-FEM solution for nonlinear wave-structure interaction using Boussinesq-type equations, Coastal Engineering, vol.55, issue.3, 2008. ,
DOI : 10.1016/j.coastaleng.2007.09.005
Spectral/hp discontinuous galerkin methods for modelling 2d boussinsq equations, Journal of Computational Physics, vol.210, 2006. ,
Numerical solution of fully nonlinear and highly dispersive boussinesq equations in two horizontal dimensions, Int. J. Numer. Meth. Fluids, p.44, 2004. ,
A time-dependent numerical code for extended boussinesq equations, Journal of Waterway, Port, Coastal, and Ocean Engineering, vol.120, pp.251-261, 1995. ,
A fully nonlinear Boussinesq model for surface waves. Part 2. Extension to O(kh)4, Journal of Fluid Mechanics, vol.405, p.405, 2000. ,
DOI : 10.1017/S0022112099007247
Numerical simulation of a nonhydrostatic shallow water model, Computers&Fluids, vol.47, issue.1, 2011. ,
A symmetric formulation for computing transient shallow water flows, Computer Methods in Applied Mechanics and Engineering, vol.163, issue.1-4, pp.111-122, 1998. ,
DOI : 10.1016/S0045-7825(98)00007-3
Streamline upwind Petrov-Galerkin formulations for convection dominated flows with particular emphasis on the incompressible Navier-Stokes equations, Comp. Meth. Appl. Mech. Engrg, vol.32, pp.199-259, 1982. ,
Isogeometric analysis: CAD, finite elements, NURBS, exact geometry and mesh refinement, Computer Methods in Applied Mechanics and Engineering, vol.194, issue.39-41, pp.39-414135, 2005. ,
DOI : 10.1016/j.cma.2004.10.008
A new finite element formulation for computational fluid dynamics: IV. A discontinuity-capturing operator for multidimensional advective-diffusive systems, Computer Methods in Applied Mechanics and Engineering, vol.58, issue.3, pp.329-336, 1986. ,
DOI : 10.1016/0045-7825(86)90153-2
Stabilized Methods for Compressible Flows, Journal of Scientific Computing, vol.190, issue.10, pp.343-368, 2010. ,
DOI : 10.1007/s10915-008-9233-5
From the paddle to the beach -a bousinesq shallow water numerical wave tank based on madsen and sørensen's equations, Journal of Computational Physics, vol.231, pp.328-344, 2012. ,
An unstructured finite volume boussinesq model for near shore applications. presented at " Frontiers of Computational Physics : Modeling the Earth system, Boulder (CO), 2012. ,
An unstructured finite volume numerical scheme for extended 2D Boussinesq-type equations, Coastal Engineering, vol.69, pp.42-66, 2012. ,
DOI : 10.1016/j.coastaleng.2012.05.008
Derivation of asymptotic two-dimensional time-dependent equations for surface water wave propagation, Physics of Fluids, vol.21, issue.1, 2009. ,
DOI : 10.1063/1.3053183
Numerical modelling of boussinesq equations by finite element method, Coastal Engineering, vol.37, 1999. ,
A first-order system approach for diffusion equation. I: Second-order residual-distribution schemes, Journal of Computational Physics, vol.227, issue.1, pp.315-352, 2007. ,
DOI : 10.1016/j.jcp.2007.07.029
An alternative form of the boussinesq equations for near-shore wave propagation, Journal of Waterway, Port, Coastal, and Ocean Engineering, pp.618-638, 1994. ,
Boussinesq-type modelling using an unstructured finite element technique, Coastal Engineering, vol.50, issue.4, 2004. ,
DOI : 10.1016/j.coastaleng.2003.10.005
A new form of the boussinesq equations with improved linear dispersion characteristics. part 2: a slowing varying bathymetry, Coastal Engineering, vol.18, pp.183-204, 1992. ,
Long waves on a beach, J.Fluid.Mech, p.27, 1967. ,
High order preserving residual distribution schemes for advection-diffusion scalar problems on arbitrary grids, 2012. ,
On the C-property and Generalized C-property of??Residual Distribution for the Shallow Water Equations, Journal of Scientific Computing, vol.228, issue.1, pp.304-318, 2011. ,
DOI : 10.1007/s10915-010-9369-y
URL : https://hal.archives-ouvertes.fr/inria-00538844
Application of conservative residual distribution schemes to the solution of the shallow water equations on unstructured meshes, Journal of Computational Physics, vol.222, issue.1, pp.287-331, 2007. ,
DOI : 10.1016/j.jcp.2006.06.024
URL : https://hal.archives-ouvertes.fr/inria-00402649
Stabilized residual distribution for shallow water simulations, Journal of Computational Physics, vol.228, issue.4, pp.1071-1115, 2009. ,
DOI : 10.1016/j.jcp.2008.10.020
URL : https://hal.archives-ouvertes.fr/inria-00538892
Numerical simulations of nonlinear-wave propagation over a bar, Coastal Engineering, vol.23, pp.1-16, 1994. ,
Further enhancements of Boussinesq-type equations, Coastal Engineering, vol.26, issue.1-2, pp.1-14, 1995. ,
DOI : 10.1016/0378-3839(95)00017-2
A new approach to handle wave breaking in fully nonlinear boussinesq models, Coastal Engineering, vol.67, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00798996
Hybrid finite volume ??? finite difference scheme for 2DH improved Boussinesq equations, Coastal Engineering, vol.56, issue.5-6, 2009. ,
DOI : 10.1016/j.coastaleng.2009.01.001
A numerical method for extended boussinesq shallow-water wave equations, 1999. ,
A finite element method for the two-dimensional extended Boussinesq equations, International Journal for Numerical Methods in Fluids, vol.7, issue.10, 2002. ,
DOI : 10.1002/fld.349
The limit of applicability of linear wave refraction theory in a convergence zone, 1971. ,
A stabilized finite element formulation for the incompressible navier-stokes equations using a hierarchical basis, International Journal for Numerical Methods in Fluids, vol.35, 2001. ,
