New interface
Journal articles
Variability in the rigidity of Coffea canephora Pierre stems determined by acoustic analysis
Abstract : The physical characteristics of wood are not usually taken into account in the genetic improvement of perennial species cultivated for their fruits or seeds. Yet in coffee trees, stem breakage during harvesting, or lodg- ing during their development are major defects in some cultivars. Such defects are linked to certain mechanical properties of the wood, such as stiffness, which can be characterized by the modulus of elasticity (Eb), a param- eter used in the theory of mechanics of solids. The longi- tudinal Eb of several clones of the species Coffea cane- phora Pierre was assessed. The Eb was measured using a vibration analysis system developed at CIRAD, the "Bing" system. It is based on an analysis of vibrations caused by a blow to the tip of a piece of wood of known geometry. The Eb obtained in this way revealed substan- tial variability within the C. canephora study sample. Clone classification according to stiffness made it possi- ble to identify the clones most susceptible to lodging. This technological characteristic of wood is highly heri- table (0.64), meaning that effective improvement of this trait is feasible. This parameter could also be used as a predictor of other traits of agronomic interest, such as re- sistance to borer insects.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-00827470
Contributor : Christophe Godin Connect in order to contact the contributor
Submitted on : Wednesday, May 29, 2013 - 11:33:02 AM
Last modification on : Saturday, August 6, 2022 - 3:46:32 AM
Links full text
Identifiers
Citation
Christian Cilas, Christophe Godin, David Grenier, Christophe Montagnon, Henri Baillères. Variability in the rigidity of Coffea canephora Pierre stems determined by acoustic analysis. Trees - Structure and Function, 2002, 16 (1), pp.23-37. ⟨10.1007/s00468-001-0140-8⟩. ⟨hal-00827470⟩
Share
Metrics
Record views
115
