Joint T1 and brain fiber diffeomorphic registration using the demons - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2012
Image registration is undoubtedly one of the most active areas of research in medical imaging. Within inter-individual comparison, registration should align images as well as cortical and external structures such as sulcal lines and fibers. While using image-based registration[1], neural fibers appear uniformly white giving no information to the registration. Tensor-based registration was recently proposed to improve white-matter alignment[2,3], however misregistration may also persist in regions where the tensor field appears uniform[4]. We propose an hybrid approach by extending the Diffeomorphic Demons(D)[5] registration to incorporate geometric constrains. Combining the deformation field induce by the image and the geometry, we define a mathematically sound framework to jointly register images and geometric descriptors such as fibers or sulcal lines.
ohbm2012.pdf (2.96 Mo) Télécharger le fichier
hal-00828387 , version 1 (30-05-2013)
  • HAL Id : hal-00828387 , version 1
Viviana Siless, Pamela Guevara, Xavier Pennec, Bertrand Thirion, Pierre Fillard. Joint T1 and brain fiber diffeomorphic registration using the demons. Organization for the Human Brain Mapping, Jun 2012, Beijing, China. ⟨hal-00828387⟩
188 Consultations
150 Téléchargements
